debadging 2005 r53 mini cooper s?
if dental floss is not strong enough ive found that dynema fishing line works wonderfully however you have to be careful to not cut yourself with it.
once youve removed them there is likely to be some ghosting whether from UV wear or physical wear on the surround paint and it is best to do this in conjunction with a detail. If there is a noticeable texture difference because the emblems were put on while the paint was soft this can be fixed with a quick wet sand
