noob question but what kind of tape?
Old Nov 6, 2012 | 09:03 AM
raffy888's Avatar
raffy888
Ok so my Mini Cooper has plastic trims everywhere especially on the lower bottom part of the car. I have never polished or waxed the car because I am still unsure on how to keep the plastic away from polish and wax. Anyway I researched and most of the "detailers" put tape over the plastic trims so it wont get polish or wax on it. Now when I did my research they did not really tell me what kind of tape they use. I found some "Meguiar's masking tape" in autogeek but is that the right tape? I am sorry for this noob question but any help would be appreciated! thanks for reading!
Old Nov 6, 2012 | 09:19 AM
Ta87's Avatar
Ta87
You could probably use any kind of masking tape. I have some left over blue painters tape from when I plastidipped so I use that.
Old Nov 6, 2012 | 09:34 AM
CR&PW&JB's Avatar
CR&PW&JB
Masking tape can leave a little adhesive residue behind.
I use the widest painter's tape I can find.
And make sure you put the edge of the tape on the body panel and not just the plastic trim. It won't stick to the plastic trim very well and when you polish and touch it, it comes loose. Just overlap the painted body panels by a quarter inch.
You'll get some polish/was residue along the edge when you pull the tape off, just wipe it off... good to go.
Old Nov 6, 2012 | 09:43 AM
Day177017's Avatar
Day177017
Blue painters tape. Any hardware store will carry it.
http://www.homedepot.com/h_d1/N-5yc1...kuId=202889344
Old Nov 6, 2012 | 06:49 PM
greengobln's Avatar
greengobln
I like the green automotive painter's tape when you can find it. auto zone has it sometimes. I've seen it at MAB and sherwin williams too. Having said that i use the delicate surfaces blue painters tape in the 2" width that is available everywhere. walmart home depot etc. it leaves less residue in my experience.
Old Nov 8, 2012 | 08:57 AM
raffy888's Avatar
raffy888
thanks alot for the comments and suggestions! will definitely check out the painter's tape! thanks again guys!
Old Nov 11, 2012 | 09:39 AM
Ch28Kid's Avatar
Ch28Kid
Green... its not as sticky.
Don't use normal white ones... Leave so much glue behind.
MiniJess
Detailing 101
30
Aug 4, 2016 03:43 PM
STR3T
May 23, 2016 03:27 AM
Drumsound
Aug 25, 2015 05:22 AM
JHolland
Aug 24, 2015 07:04 AM
SamtheSham152
R57 :: Cabrio Talk (2009+)
Aug 14, 2015 07:01 PM
