Clay bar? Who has the best?
Originally Posted by danbanger
After washing your car before claying it, do you need to dry it (thoroughly at least)?
Originally Posted by dominicminicoopers
>> I love zaino products, but actually didn't really like the feel of their clay, and while it did a good job, It just seemed harder to fold and work with.
That's odd, I found the Zaino clay to be extra plyable and even left behind a couple of bits of itself. I clayed in the shade, but it was still about 108 F that day. So maybe the heat made it extra pliable.
One note: I kept my clay bars in the jar they came in with the lid tightly closed; he kept his in the plastic it came in, unsealed, with air exposure.
Originally Posted by no_affiliation
The Mother's clay bar system you are supposed to dry the car completely. Then apply the spray they provide you to the target area, then clay it, polish it out.
Zymol's Lehm Klay?
I have some Zymol Lehm Klay coming in the mail. I have always liked their other products, so I thought I would try it.
Interesting note, Zymol strike, which is a citus-based engine cleaner, can be diluted and used sparingly on dirty paint. (According to the distributor who sold me the Lehm Clay) He recommended I try that first.
Clay Bar?
Ok, so you wash and then clay bar? Once you drop the clay bar, it's no good because you get dirt in it, correct? So you can only use the clay bar once? You do the car, there's dirt in the clay bar.
I pretty much call my piece of clay "dead" if I drop it. Just like if I drop my microfiber on the ground, it automatically goes in the hamper to be washed.
This is what I do. I tear very small pieces of claybar off the large bar. I knead down and flatten them into a very thin wafer about the diameter of a silver dollar. I use the bar on one side until it gets visually dirty. Then I flip it over and use the opposite side. Then I throw it away.
I don't like to be tempted to use larger pieces and then knead the dirty sides into each other until a clean surface appears. This is dangerous because at some point that dirty debris is going to possibly come to the surface and cause a scratch. By using smaller disposible pieces it is MUCH safer.
And if a small piece falls on the ground and gets contaminated it is less of a waste.
I recently tried the Clay Magic clay bar on two fairly new cars (I tore it in half). On one, my Mini, I was surprised how much gunk it collected. On the other, I was surprised how little gunk it grabbed. btw, I used soapy water as a lubricant on the Mini and the Clay Magic spray lube on most of the other car (I ran out...), but I doubt this makes any difference.
Brad, I'm curious how many "silver dollars" you make out of a Clay Magic sized clay bar. Also, how many "dollars" do you typically use on your Mini?
As you might guess, different bars come in different sizes/weights. But on average I cut/tear my individual bars into about 8-10 pieces.
My cars are garaged and pampered so they are pretty clean. I can get away with one "dollar" usually for the top surfaces, one for the side above the beltline and one each (right and left) for below the beltline (rocker area). You use more here because it's usually dirtier here. Thats about 4 "dollars" a clean car, roughly. The dirtier the car, the more you will use.
It doesn't take much to do a good job and the job goes pretty fast.
Do not use the whole bar. Cut it up and use small pieces. A Mothers bar can easily be cut into 10 pieces. I work it into thin wafers the size of silver dollars. Lay this flat against the paint between your flattened palm (fingers) and rub very lightly in back and forth motions. It takes only three or four strokes in any given area. Make sure to get even coverage. You can feel when it makes the surface slick. Be sure you are using NOT just PLAIN water but a mixture of a quality auto shampoo or use with a quality quick detailer. You want to lubricate the surface. Water alone is not enough.
Look at THIS.
Look at THIS.
Thank you, Brad!
Thanks! Claying makes more sense to me now. I will "clay" this weekend. I wish I wasn't so nutsy about cleaning my car, but I love it so and it's pretty when it's all shiney.
MC/2004/Chili/ 3 packages/CVT/
What do you think the lowest outside temperature can be to use the claybar? I used it today when it was around 55-60 degrees but the clay wasn't molding easily.
Also, is it necessary to re-wash my car since I used clay prior to using the Zaino polish?
I previously had 4 layers of Zaino on my car. Did claying remove it?
Thanks everyone for being so supportive.
There is no minimum temperature that clay won't "work" but at you discovered, it get's harder to fold and bend as the temperature drops. I tend to use very small, very thin (1/16") pieces so I have no difficulty even in sub 50 degree weather. But that is usually the general cutoff. HINT: Keep the bar in your pocket to keep it warm.
Yes, it's best to wash with Z7 to remove any residue.
Claying did not "remove" all the Zaino but it likely abraded into a layer.
^^ i found that actually the blue meguiar's clay is pretty coarse. too coarse for my nissan paints. i recommend the Griot's yellow ikky mud for it's softness for newbs.
wear gloves prior to use so it doesn not appear that you had your hand where it wasn't suppose to be. the yellow dye will get under your nails.
this is by far good stuff.
http://www.griotsgarage.com/product/...rrivals&page=1
this is by far good stuff. http://www.griotsgarage.com/product/...rrivals&page=1
mom's clay is actually pretty good. the problem with their clay is that it's firm and difficult to kneed unless your hands are pretty warm. tough to do on a colder/cooler day.
the werd though, the mom's clay (although firm) is actually gentle on the paint.
WannaMini - another trick to using the Griot's mud is to use ample QD. otherwise it's so soft it will smear a light mark on the surface. you can remove the smear very easily with the clay but just a hassle at times.
once you get the hang of it, thing is fabulus. but make sure you wear gloves for sure. thing is gooey, ikky, messy.
Am I doing something wrong? I use plenty of water, but the bar is STIFF and it doesn't soften up and I feel like I'm damaging the paint. My bar is Mother's.
