EZ pass question?
I mounted mine with the included Velcro on the rear panorama window.
I positioned it as far forward as possible in the center of the glass. i forget it is there. As soon as you close the shade, it is out of mind...
I travel out to Dulles every day and have never had a problem getting the sensor to deduct the fare.
... of course, if you don't have a sunroof, this isn't much of a solution.
It works. It works great. I use it everytime I go up/down the toll road and when I drive up to Boston. I have mine mounted on the windscreen, but we use it in Michael's car sometimes by just holding it up. The "stealth" mount along the sunroof also works. Paul! has his mounted that way.
Thanks for all the super quick responses! Since it is free and money does not expire I figure what the hell...
I forgot about the sunroof mount, out of sight-out of mind.
Originally Posted by sagworks
Will the EZ pass work in the area (Dulles toll road) by holding it up when you go through the lane or does it need to be 'mounted' someway?
Those things can be read from almost anywhere.
Mine was low on $$, so I figured I would put it in the pocket behind the seat and take a ticket...well you got it...it still read it from the pocket behind the seat!
I like the rear sunroof mounting idea. I usually just set mine on the dashboard but if I forget to remove it there is a lovely sound that follows after I take a sharp turn and it goes flying into the door.
Aren't all sunroofs tinted?
Originally Posted by ssallykat
If you have your sunroof tinted, the stealth mount in the rear sunroof doesnt work.
Originally Posted by mdsbrain
I just got a new EZ Pass and it came in a electrostatic bag and the bag says, "If you don't want your EZ Pass to be used keep it inside this bag"
You can always test it out on the Dulles Toll Road (but not the Dulles Greenway). Thanks to that Washington Post article, everyone knows that the cameras don't work on the toll road, so no tickets ever get sent out to violators unless you are in an actual lane and the toll attendant writes up your license plate number...
I have two employees that have never paid a toll in over two years - they go through the high speed lanes on 267, and only use the exit lanes in rush hour when the lane bars are up to facilitate traffic.
Basically, my point was that way if it doesn't work wherever you choose to mount it, it won't matter 'cause you won't get a ticket!
in most states, you can alternatively request a thin black unit that fits on the front license plate mount rather than the standard white interior unit. in NYC area, they often issue these for european cars with heavy OEM window tinting. or did anyway. I had one on the volvo until it got smushed (don't ask - I don't tell stories about my lovely wife). call the easy-pass folks if you think you might want one of those instead. it's a little more stealthy, but some urban areas report theft issues.
--tdm
--tdm
