DC Metro MINIs (Archive) The old DC Metro MINIs club forum, now closed. Visit their new forums at www.dcmetrominis.org/forums
Supercharger Failure 2003 MCS (R53)
Old May 18, 2007 | 05:26 AM
JimCarhart's Avatar
JimCarhart
Had a "rotational" rattle that built quickly over about 300 miles (50K on the odometer), took it in ... the dreaded supercharger replacement because the waterpump impeller is breaking up (and taking the supercharger drive gear with it). See this thread for similar situation details;
https://www.northamericanmotoring.co...ad.php?t=74674
Any DCMM'ers been through this yet? I have the extended service warranty, so Mini of Sterling is out seeing if it's covered in this case.
Regardless of who pays for it, I'm gonna take the oppurtunity to slap a 15% reduction pulley on the new one. The way I look at it, turn a sad into a smile somehow.
Anyway, just curious if anyone else has been through this.
- Jim
Old May 18, 2007 | 05:48 AM
JAB 67's Avatar
JAB 67
My 2004 MCS s/c failed at approximately 16K; replaced under warranty, also at Sterling.
Insist that they show you the s/c once they remove it, before they send it back to MINI, and take pictures if you can of the damage. In particular, try to determine whether the problem was caused by loss of lubricant.
Wagnbat's Avatar
Wagnbat
An unmodified supercharger might *not* be covered by the extended warranty?
Old May 18, 2007 | 06:05 AM
JimCarhart's Avatar
JimCarhart
Just heard from Mini of Sterling ... I have the extended Service Warranty, not the extended Driveline Warranty. Therefore, yes it's not covered.
Old May 18, 2007 | 06:12 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Here's hoping that they install the upgraded teflon coated supercharger from the 05/06 models.
Old May 18, 2007 | 06:36 AM
Wagnbat's Avatar
Wagnbat
Meh. Time to upgrade to the M7 Supercharger then.
Old May 18, 2007 | 08:17 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I saw a SC that needed replacement because it had 100k miles on it. It had pretty much seized up. But 100k is the expected lifetime of the SC so it was to be expected. Just stick with the factory SC.
Old May 18, 2007 | 08:23 AM
JimCarhart's Avatar
JimCarhart
Yeah, I understand and "expect" a SC replacment (regardless of condition) at 100k with a MCS (R53) under Mini recommended maintenance.
Sadly, I'm only half-way there and I have a SC waterpump/aux gear failure. Stuff happens. I'm not bitter about it. It's a mechanical device (the car). In the scheme of things ... bigger things can break in life and not be replaced.
The M7 upgrade looks like a stock SC with extra material added outside (for stiffness) and ported on the inside. Interesting concept.
I'm gonna stick with stock at this time, and reset the ticker for hopefully 100k additional miles before that SC fails.
Old Dec 20, 2008 | 03:47 PM
richardsd3's Avatar
richardsd3
I have a 2003 MCS supercharger failure with 70K Mi. The replacement is $1850 + $400 labor. Pretty expensive little toy to maintain. The SC shaft wobbled in their shot bearings. The teflon coating was scraped off the rotors and a little oil was left in the housing. My mechanic gets $60/hr vs $120/hr dealer rates. He says the failure is due to a speedup pulley and non stock belt. I wonder what's next? What does BMW say about this? I like the car and have added a continental kit spare tire.
Old Dec 20, 2008 | 05:33 PM
JustJAY's Avatar
JustJAY
WOW 1.5 year old thread brought back from the dead
Old Dec 20, 2008 | 06:02 PM
JimCarhart's Avatar
JimCarhart
Yeah, boy talk about the wayback machine. Anyway, my SC failure (oil gone from the SC gearbox) was not due to overspin due to reduction pulley. It's a "common" in the sense of seen often enough to be noted condition. The oil in the chamber that contains the SC gear drive is a fixed amount at manufacture in a sealed chamber. Go figure, engineering design choices.
- Jim
Old Dec 20, 2008 | 10:04 PM
Mr EZ's Avatar
Mr EZ
So that means that I'm at 88 K and will suffer a failure in no time????
Old Dec 21, 2008 | 09:51 AM
Funnynuts's Avatar
Funnynuts
Dang i have not heard about this in a good long while I knock on wood as i write this i got 163k on my S/C still sings when i get on it and hope to keep it that way as a consider a 12% pully
Old Dec 22, 2008 | 06:02 AM
JimCarhart's Avatar
JimCarhart
As posted, no it doesn't "mean" your SC gear will implode @ 70k. It's just common enough condition to be a known situation.
Advice? I know nobody asked for advice, but here it goes ... if you are planning on keeping a early build (pre 2004) MCS for long term (greater than 150k miles) it makes sense to consider picking up a spare SC assembly.
Wait, did I just say that? I don't have a spare and I already lost my original! The point is the SC isn't going to get cheaper and as you keep the car longer ... I'd be more comfortable with a spare built up SC at hand.
Am I being too **** about that? Maybe, but I keep spare pads, rotors, wiper blades and wiper rubber around. Why? They are consumables and require regular replacement in the long life of a vehicle. I plan for their replacement and don't scramble when they need to be replaced at times when I may not have the luxury of dollars/time to deal with them.
Yes, I keep vehicles around for a long time. I don't think I've ever replaced a vehicle with less than 175k miles on the ticker. Much the less something special like a R53 Mini Cooper. Note that resale to someone interested in a vehicle is easier when you have complete service records and spares to go with it. "See, here is the proof that I took good care of this car, now you can too." It also helps with the negotiations on asking price, it raises the confidence of the buyer in the perceived value of the car.
Concerning a MCS I'd be remiss if I didn't mention that until I replaced the cat-back exhaust with a Milltek, I also kept around a pair of rear exhaust hangers for my MCS. Another known "early replacement" stock part issue.
- Jim
sevin
May 2, 2026 06:11 AM
bobbiemartin
Jan 20, 2016 05:28 PM
alistaircookie
Oct 8, 2015 10:52 AM
PrimePower
Aug 16, 2015 06:29 PM
PrimePower
Aug 11, 2015 12:51 PM
