D Stock Rattle After Koni DA install
So, I've just realized that since the shocks were put on the car I've got some extra sound coming from the right rear. It's pretty consistant over stuff like like potholes, but seems to be hit or miss off the left rear wheel.
Pulled the right rear wheel and and everything looks right. (It was torqued to spec so I know it wasn't a loose lug and I would have felt that in the handling.)
No odd wear points on what I could see. Everything appeared to be nice and tight. Adjusted the rears to one click off full soft (assuming "Heavy" is firm) and moved the fronts to a half turn from full soft and went out and enjoyed the understeer.
Not a lot of clearance for that adjuster.
At first it sounded like I had something loose in the hatch. Or maybe the privacy panel bouncing a bit in its hinge. Pulled the panel out and checked the light access on the right hand side and didn't see anything noticeable. Checked the battery. Everything as it should be.
Came home. Parked the car. Noticed the exhaust (Milltek catback) had slid a bit to the right of center in the valence. Wondering if that's the culprit, but it's not a very metallic sound.
Maybe with the stiffer shocks it's getting the rear seatback or something to move a bit? Or just transmitting more road noise? I could probably get it back into the shop to have it checked, but was wondering if any one here with the same shocks had experienced anything similar.
This is a very common problem, mine did the very same thing & I was led to believe it's because the shaft that comes through to top strut mount is larger then the hole it must pass through, so you have to drill it out some. If it rattles afterwards you shim it with some washers which is what I did & rattle gone. crank them down good & tight too.
I know that driving around on what passes for roads here in the Peoples Republic of Ohio causes "Loose Nut Syndrome" or LNS. It seems like I have to drop the rear struts out every coupla months to tighten the big nut on top of the shock. Not sure what the torque should be, but I'm cranking the hell out of it. Anyone use "locktite" or use another nut to lock it down?
Doesn't the shaft spin when you tighten the big nut? (that sounded a little weird...sorry).
Most people just zap it with an impact gun. I wouldn't go crazy with it though. It can't be too good to spin the shaft too much.
The impact gun has always worked for me. (on many other cars and now the Mini.....although we have Leda's not Konis)
squawSkiBum
10-02-2015 09:21 AM
