D Stock Engine mounts replacement and stay in DS
Old 09-24-2016, 09:37 PM
jonp's Avatar
jonp
jonp is offline
Hi, I just bought a 2006 Cooper S JCW and planning on running in DS. My question is the engine mount is failing like most OEM mounts in the 2004 to 2006's can you replace the mounts with a aftermarket mount and stay in DS, if so which one's.
Old 09-25-2016, 04:06 AM
cmt52663's Avatar
cmt52663
cmt52663 is offline
Section 13 of the SCCA Solo Rules reads partially thus:
"Alternate components which are normally expendable and considered
replacement parts (e.g., engine and wheel bearings, seals, gaskets, filters,
belts, bolts, bulbs, batteries, brake rotors, clutch discs, pressure plates,
suspension bushings, drivetrain mounts, fenders, trim pieces, fuel filler
caps, etc.) may be used provided they are essentially identical to the standard
parts (e.g., have the same type, size, hardness, weight, material, etc.),
are used in the same location, and provide no performance benefit."
Unless you expect to trophy at Nationals I would not worry about it.
Kind regards,
Charlie
Old 09-25-2016, 04:35 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
6th Gear - AX Champion
uhh not sure I would do it if you are competitive, they are supposed to cut down on wheelhop and that is an advantage in autocross
I have not tried one to see if that is true
bartolucci
11-18-2016 06:30 PM
Nebski18
08-29-2016 03:29 PM
KerMINI06
17
08-19-2016 04:34 PM
Rockrunner
08-11-2016 08:04 PM
Dino S
08-10-2016 12:25 AM
Quick Reply: D Stock Engine mounts replacement and stay in DS
