D Stock Hey Mods!
C-Stock now includes-
Cooper S JCW 2006-2010 (factory installed)
Clubman S JCW 2009-2010
Any Cooper S JCW of earlier years not factory installed is excluded.
You compete with-
BMW M coupe and M Roadster 1996-2000, M3 (E30 and E36), Z3 6 cycl.
Corvette 1963-82
Ferrari 308 and 328
Lotus Espirit non turbo
Mazda Mazdaspeed Miata 2004-05, Miata 1.8L 1999-2005, Miata MX-5 2006-2010, RX7 Turbo 1987-91, RX8
Mercedes SLK
Morgan plus 8
Nissan 300ZX Turbo 1990-96, 350Z 2003-09, 370Z 2009-2010
Pontiac Solstice (non-GXP) 2006-09
Porsche 356 Carrera (4-cam), 911 (non-turbo), 911 Club Sport,914, 928, 944 (also with turbo), 968, Boxster (986 chassis, non-S 1997-2004, Carrera 2 & 4 (964 chassis).
Saturn Sky 2006-09
Toyota MR2 Spyder, supercharged, and turbo
In my region the front finishers are-
Miatas, MR2, and nationally the Solstice competes well.
Good luck, a class with good competition.
You compete with-
Corvette 1963-82
Ferrari 308 and 328
Mercedes SLK
Morgan plus 8
Saturn Sky 2006-09
You compete with-
Corvette 1963-82
Ferrari 308 and 328
Mercedes SLK
Morgan plus 8
Saturn Sky 2006-09
You compete with-
Corvette 1963-82
Ferrari 308 and 328
Mercedes SLK
Morgan plus 8
Saturn Sky 2006-09
on
It actually has a Shot in C-Stock. You gotta Kick and push the front struts for some tiny amount of camber but the 09 JCW should actually have a shot. I'd put 245/40's on those wheels though. It's gonna be course dependent. Anything with sweepers it's over. Anything with transitions and low speed corners your coming out of a dig it's got a shot. The one time I autox'd our Mini it was an 03 with header, pulley and JCW springs and R6's (not A6's) and Open diff, it ran 1.3 seconds behind the current (at the time) A-Stock national champion in his S2k CR. I'd think a 09 JCW is going to make more power and torque then I had at the time and run an A6 tire it should be competetive in C-stock. SHOULD.
Yes, it is.
Currently SCCA stock classes for the MINI are-
COOPER (All models)= H-Stock (HS)
COOPER S (All models)= D-Stock (DS)
2006-2012 MCS JCW = D-Stock (DS)
2009-2012 Clubman S JCW = D-Stock (DS)
Permitted Modifications
• Any Struts - including adjustable damping
• Any substitution, addition or removal of a single anti-roll bar
• Panel Air Filter in stock air box
• Any Cat-back exhaust
• Harnesses (Quick-fit or similar) and C.G. Locks
• Wheels must be stock size and stock offset within 5mm. This means 15x5.5 and 16x6.5 for the MC and 16x6.5 and 17x7 for the MCS.
• R-compound Tires - Hoosier A6, Kumho V710, or similar. Street tires are also acceptable, but won't be very competitive since race tires are permitted in this class.
• Brake pads may be replaced
• Spare tire and tool kit may be removed
• Roll bars or roll cages may be added
• airbags may not be removed
Basically, that's about the extent of the modifications that can be done. Lowering Springs, camber plates, camber links, cone filters, lighter seats, interior gutting, headwork, cams, engine dampeners, USS, Strut Braces, BBK's, brake stiffeners, slotted rotors, etc..... ARE NOT PERMITTED IN STOCK CLASS.
COOPT UP
09-11-2015 04:59 AM
larryd96
11
09-08-2015 05:01 AM
