'06 R53: What's causing the howling noise?
Old May 20, 2007 | 08:29 PM
abuzavi's Avatar
abuzavi
So, I've got an R53, 2006 with sun roof.
When getting up to speed (autobahn), it'll start to making this howling sound -- sometimes.
Sometimes, it starts at around 95 mph -- sometimes more, sometimes less. Sometimes not at all.
At first, I thought it was coming from the top of the windshield area. Now I'm thinking it's from up front, below the windshield.
What's causing it and, much more importantly, how do I mitigate it?
Old May 20, 2007 | 11:40 PM
Qksquirt's Avatar
Qksquirt
Under approximatly the same conditions, on a windy day, I noticed that the windsheild wipers tend to vibrate and make a screech that will scare the heck out of you the first few times it happens.
Old May 21, 2007 | 03:33 AM
BlimeyCabrio's Avatar
BlimeyCabrio
It's Blimey's screams of envy coming across the pond.
Old May 21, 2007 | 03:38 AM
jonnieoh's Avatar
jonnieoh
Could be wipers, could be cowl vent, could be the A-Pillar covers. I've heard of them making whistling noises when they're not fully on.
Old May 21, 2007 | 03:56 AM
abuzavi's Avatar
abuzavi
Blimey / Paul,
I said that it sounds like howling, not like a crying little girl.....
Wipers, vents, pillar covers -- things to check tonight at the house.
Old May 21, 2007 | 04:06 AM
BlimeyCabrio
Originally Posted by abuzavi
Blimey / Paul,
BWAH HAH HAH!!!!
You mean old bully, you hurt my feelings.
I hope somethin flies off that ugly old black car. Somethin 'spensive.
Could always strap one of the kids to the bonnet and have them adjust things while you drive at that speed until it goes away... which one do you like the least? I mean your kids, not MY kids...
Yeah - I've heard some comments about the seal around the windshield making noise...
Old May 21, 2007 | 05:07 AM
jibeho's Avatar
jibeho
My vote is the cowl vents. I got it one time going 75 into a 25 MPH headwind giving me an apparent wind speed of 100mph. I turned on my wipers and the sound did not change.
Old May 21, 2007 | 06:14 AM
BlimeyCabrio
A little painters tape over the cowl vents would be a good test of this theory.
Probably like a giant blowing over the top of a giant beer bottle...
Old May 21, 2007 | 06:19 AM
princeofwaldo's Avatar
princeofwaldo
If it makes a difference, mine makes the same noise at high speed. If you have not made your Mini howl, you have not been fully appreciating the cars capabilities!
Old May 21, 2007 | 07:07 AM
Gromit801's Avatar
Gromit801
Mine is caused by the windshield, and I suspect is has to do with the moulding and weather stripping around the windshield.
Old May 21, 2007 | 07:52 AM
abuzavi's Avatar
abuzavi
Gromit -- how did you confirm / deny that? Do you think it's the moulding / weather strip, or do you know it's the moulding / weather strip?
Old May 21, 2007 | 08:02 AM
jreaney's Avatar
jreaney
Mine too
My 05 MCS does this sometimes as well - Try putting the AC on recirc and see what happens - mine goes away if you do this. But I dont run at 90+ most of the time.
Old May 21, 2007 | 08:53 AM
abuzavi's Avatar
abuzavi
I actually tried the re-circulation trick yesterday -- no luck. I was doing about 110, though.
For me, success is being able to hold 110 or 120 without the howling (or hearing Blimey crying about it -- Bring it on, Paul, bring it on.... )
Old May 21, 2007 | 09:30 AM
Gromit801's Avatar
Gromit801
When it started howling, I could place my hand on various parts of the windshield, and push slightly from the inside, and the sound would change, or go away completely until I released my hand.
To me, that says weatherstripping or molding not fitting properly. Air possibly getting up under the molding, and creating a harmonic vibration.
Old May 21, 2007 | 09:42 AM
Poppa Bear's Avatar
Poppa Bear
Abu, check this thread. I'd read something about the A-pillar being a potential problem but hadn't had too many episodes personally.
I'm curious to know how/if you remedy this as I'll probably use your fix!
Cheers!!
Old May 21, 2007 | 09:58 AM
abuzavi's Avatar
abuzavi
Poppa Bear -- Yeah, I had skipped that thread because of the horrible subject line. That'll teach me, I suppose.
I've got some more research to do, and some more driving. It's a most curious problem, probably moreso for us here in the old country.
Old May 21, 2007 | 12:48 PM
BlimeyCabrio
...(or hearing Blimey crying about it -- Bring it on, Paul, bring it on.... )
Dude, you're evil. And you're a crafty little bugger, too. Tormenting me this way.
By the way, Heroes season finale tonight...
Just start playing around with painter's tape - for the windshield, run a strip across the top to "seal" the joint between the windshield and the trim, and the trim and the roof...
At some point you're bound to find something that makes a difference. And each test is an excuse to drive triple digit speeds...
Old May 21, 2007 | 07:52 PM
Poppa Bear's Avatar
Poppa Bear
Abu, seems like you're one of many as I've found another thread with the same issue. Good luck!
Cheers!!
Old May 21, 2007 | 09:37 PM
daflake's Avatar
daflake
Sorry bro, that is me passing you!
As others have mention, painters tape is a good test for this. You can run this tape down various areas to see if you can deaden the noise. I have a howling noise at 90, but I know for a fact it is my tires. Those Dunlops are noisy buggers, but they do have pretty good traction.
Old May 25, 2007 | 07:37 PM
SirMini's Avatar
SirMini
I have the noise too, but my son was in the pass. seat and said it was the wiper vibrating. I think I'm going to try the tape idea to see if it is for sure. Thanks for the tip!
Old May 26, 2007 | 06:22 AM
minjae's Avatar
minjae
hm. my car never made a whistling noise but today while going at bout 60 mph my car was making a whistling noise coming from the windshield it seemed. there's too many tiny things wrong with my car. T.T able to live with it. but it bothers me sometimes. oh well.
Old Jun 10, 2007 | 01:34 AM
abuzavi's Avatar
abuzavi
You can hear it in the background, here.
Old Jun 10, 2007 | 05:29 AM
Alerious's Avatar
Alerious
hmmmmm... is it me or is that so called howling more like a horrible screech? Or perhaps the video is making the howl more pronounced? I've certainly never heard anything like that before. You should bring a passenger with you so they can feel around and listen to where the howl is coming from, I certainly wouldn't want you to be distracted trying to pinpoint a noise when you're doing a 100+ on the autobahn.
GotMINI
Old Jun 10, 2007 | 06:54 AM
hunter99's Avatar
hunter99
I have got the howl on my '06 from time to time. Seems to mostly come from going into the wind. I also noticed mine was coming after I opened the sunroof during the day and closed it. The last tme I got the howl I just opened the sunroof a little and closed it and the howl went away. I was still driving into the wind at speed.
Old Jun 10, 2007 | 02:30 PM
paipuky's Avatar
paipuky
It is a Factory's defect, but they won't fix it...
I got the same issue... An annoying noise after 70-90mph... It comes from the windshield. The dealer replaced the windshield (under warranty), but it didn't fix the isssue... Sorry about that, I have had to ignore it. Otherwise you'll have a hard tiem with the dealer...
