Odd tire wear pattern
Old Mar 18, 2015 | 06:17 PM
jkline's Avatar
jkline
I pulled my newish NM rims (RSe 10 19") shoed with Nitto INVO 225/40R19 tires last weekend and noticed an unusual wear pattern on the front tires only. The center of the tread shows more wear than the edges. Tires checked regularly @ 32 PSI, nitrogen filled. Rears are still flat across the center. So my question is, anyone seen this on a tire before? Tires have about 8K miles on them. Is this a byproduct of the asymmetrical tread perhaps?
Old Mar 18, 2015 | 06:52 PM
Drivehard's Avatar
Drivehard
Appears to be classic under inflated. Isn't door sticker spec 35psi? ( did a Google search. Don't have a cm ). The 3 lbs with the added tire dimensions may have something to do with it?
Just me guessing.
Sent from my iPad using NAMotoring
Old Mar 18, 2015 | 07:56 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Door sticker is 32psi for 17"' don't know what happens with 19"
Old Mar 19, 2015 | 10:20 AM
hsautocrosser's Avatar
hsautocrosser
Owner manual says 16, 17, 18, 19 are all 32psi below 100mph with stock suspension. Nitto specifies 35psi for a 2013 Countryman S with 225/40-19 INVOs.
http://www.nittotire.com/passenger-t...formance-tire/
Old Mar 19, 2015 | 11:10 AM
jkline's Avatar
jkline
hsautocrosser, thanks for the link.
I will readjust my pressure, move these to the rear and see what happens.
Old May 2, 2015 | 05:54 AM
thebestbear's Avatar
thebestbear
My other thought is what is the width of the wheels?
They may be too thin which would change the contact patch profile.
Old May 3, 2015 | 06:06 AM
gjxj's Avatar
gjxj
My concern is that its alignment related. see what the tire mfg says, and have a good alignment shop look at it.
Old May 4, 2015 | 07:01 PM
jkline's Avatar
jkline
Thebestbear: Rim width is 8". NM recommended 225 or 235 on this rim. JCW 19" rims spec the same size tire, but on a 7.5" width.
Gjxj: A professional alignment was done within 50 miles of having the tires mounted. This was with the lowering springs and new adjustable rear control arms added.
Nitto does spec a higher pressure(35psi) than the stock tires/rim (32 psi), which I failed to notice. I still think that a mere 3lbs of difference of tire pressure can't explain the wear fully. We will see in another 5k miles or so if it was just pressure.
Old May 5, 2015 | 11:40 AM
RMachuca's Avatar
RMachuca
More wear in the center means its actually OVER inflated, as the center balloons outwards. Adding more air\nitrogen will make it worse. I also believe that its because of the size\setup your running, higher sidewall=more conforming contact patch, so weird wear patterns are mitigated, running such low profile exposes these little issues much more.
my .02 cents.
MyMiniS
Sep 18, 2021 05:58 AM
Tektura
Tires, Wheels, & Brakes
18
Sep 13, 2015 10:00 AM
DrFraserCrane
Aug 30, 2015 01:11 PM
col127
Aug 21, 2015 02:11 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
