Wheel Locks for NM RSe14 19" Wheels
Old May 9, 2014 | 09:16 AM
Mark Gallo's Avatar
Mark Gallo
Does anyone know of a set of wheel locks that will work with the NM RSe14 19" wheels? The stock locks won't work because the lock tool will not fit inside the lug hole.
Old May 9, 2014 | 09:55 AM
ASKtheteach's Avatar
ASKtheteach
There are two different types of wheel locks. One is MINI branded. It has the key that goes around the lock itself, which is what I think you have. The lock "pattern" is a curved shape in the face of each lock. The second kind is BMW branded. They have a key that fits into (not around) the lock. Instead of the rounded lock pattern, it has a series of teeth that the key fits into (kind of the way a gear works). They make different versions for security purposes, with differing numbers of teeth (some get 13 teeth, others get 17, etc).
These are the MINI branded ones:http://www.ecstuning.com/Mini-2012-C...cks/ES1877247/
And these are the BMW branded ones: http://www.ecstuning.com/Mini-2012-C...Locks/ES65849/
Old May 9, 2014 | 11:33 AM
Mark Gallo's Avatar
Mark Gallo
Thanks for the info! I have the BMW branded ones. Maybe they will work after all. I was going off something another forum member mentioned in a post a while back. The wheels should arrive Wednesday so I can try it out for myself. Hopefully they'll fit!
SosoMINI
Nov 22, 2015 03:17 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
