Treadwear question - front outer edges wearing fast
Old Mar 17, 2013 | 07:25 PM
chrunck's Avatar
chrunck
I noticed today that the outside edge of both front wheels are wearing significantly faster than the rest of the tire. I typically run about 40-42 psi all around. Is this the result of hard cornering? I generally don't slow down on turns. It's an All4 and the back wheels aren't worn the same way. I usually rotate tires every 5k or so.
Anything I can do, other than slowing down around corners? Would lowering springs make the problem better or worse? I never noticed this in my R53 and I drove it pretty hard too.
Old Mar 17, 2013 | 08:21 PM
countryman-s's Avatar
countryman-s
lowering springs will definately tranfer the wearing to the inside more. i would take it to the dealer, or tire shop so they can do a alignment test. uneven tire wear will waste a set of tires and cost you money you could use for something else. and dont dilly dally like i did. i had to purchase a new set of tires because i skipped the 5000 mile tire rotating once lesson learned
Old Mar 17, 2013 | 09:25 PM
dkizerian's Avatar
dkizerian
You could also try to have the alignment done and increase the negative camber in the front. This will tilt the top of each front wheel in just a little which will help with outside edge tire wear.
You also might be overdriving, which doesn't help tire edge wear.
Old Mar 17, 2013 | 11:23 PM
bmwr606's Avatar
bmwr606
my all4 does the same and i think it is from aggressive cornering
i have pirelli p7 225/45R18 summer rf tires and sport suspension
i run 42 psi front / 37 psi rear, set with a tire pyrometer and chalk
when i notice the front tire outer edge beginning to feather, i rotate the tires, front to rear
i have had the alignment checked, both at the dealer and at an independant shop whose alignment machine had the cms all4 alignment specs "built in" ... both said i am within spec
i say rotate the tires and carry on
nothing is free, hard acceleration takes fuel, aggresive cornering wears tires
i doubt i will get much more than 10,000 miles out of the p7s, they were 1/2 worn at 5,000 miles, 10/32" new tread depth, 6/32" at 5k, 2/32 done ... but all four tires are wearing evenly
scott
Old Mar 18, 2013 | 06:51 AM
chrunck's Avatar
chrunck
Thanks, Scott. I'm going to rotate next weekend (ran out of daylight yesterday) and do a quick visual of the struts, tie rods, etc. I suspect that it's from body roll and hard cornering. I'm still on the stock tires and otherwise they're wearing great. About 17k miles so far.
Now that I think back, the front edges looked really worn after I did autocross last year. Doing autocross again in a couple weeks, so we'll see. I'm going to have to do some suspension mods eventually. Maybe springs/control arms and a rear sway bar.
Old Mar 18, 2013 | 06:56 AM
Helix13mini's Avatar
Helix13mini
Have your alignment checked. It's likely that you are toe-in. If you had enough positive camber to wear out the outer rows of tire treads, your front wheels would look like a Model T.
jeremy_reyes94
Sep 6, 2019 07:53 AM
silence2-38554
Nov 12, 2015 09:39 AM
FLYM1N1
Aug 15, 2015 11:20 AM
minipopkart
Aug 13, 2015 05:22 AM
