New Target... 140-150 horse power.
Originally I halucinated at the magical 200 hp... Now I am more realisitically looking for 140-150 hp.
I know that intake, chip, header and cat back will get me close at the crank. I am still thinking of port and polish the head. A light weight flywheel, and crank pully. (yes, I know it won't do much on the dyno but will help out in the real world)
I also want to give the MINI help on the bottom end. Any thoughts to this new quest?
PLEASE no replies like, "just cancle the order for the MC and order a MCS". I am not a "Whine-o"!
Besides I get all the "Whine" I can humanly desire from my 4.5 year old and my 2 year old sons. And they don't add $2K to the cost of my Cooper!
Originally Posted by mielnicki
Chip
Intake
Exjaust
Header
New Head (ported and polished)
New Cam (custom if you want lots of torque)
New coil, plugs and wires
"S" injectors
Steve
Intake
Exjaust
Header
"S" injectors
Steve
Software, Cam, Head, Intake, and Header should get you very close, or over your target. Also, be sure to get a different exhaust (or modify the stock one... it has flow issues due to design).
We have a enlarged TB for the Cooper that may help in your quest. I think your new goal is very reasonable as well as attainable. You will still be entering a area where the transmission will be suspect and will require monitoring on your part..
Randy
M7 Tuning
Randy
M7 Tuning
Originally Posted by asodestrom
Check out MTH. They claim 160 with their MTH kit 2.
I can see that I will be spending a fair ammount of time on the Dyno. I hope to doccument everything. Including a baseline pull.
Originally Posted by tradiuz
The light weight flywheel will hurt you in the torque department when taking off, if you go too light.
Is this good enough.
Trying to remember the diameters of each brand of headder and cat back. If I recall we want the diameter to remain constant through the headder cat and cat back. This in mind the best headder might not work with the best cat back system. Unless I could get a custom cat/ cat-elimination pipe.
Randy
M7 Tuning
Randy
M7 Tuning
Originally Posted by danbanger
05 MC's with the getrag will have problems with 140-150hp still? or is it only with the midlands?
The only trouble I had seen personally was a total of three Coopers but none were 05's .
randy
M7 Tuning
I hadn't thought about S injectors. Was thinking about boring out the throttle body.
Do the throttle body, though. I'm really curious to see what result that gives you.
Maybe you would be best off forgetting about increasing power so you can focus your budget on improving handling?
If I was going to mod a Cooper I would not even bother with anything to do with power until I had done a LOT of handling improvements. . .
By the time you get 150hp out of the Cooper, it would probably be louder than a stock S anyway. . . .
Originally Posted by ahamos
Unfortunately, S injectors won't work in a Cooper. The jerks made them with different connectors explicitly to prevent us from trading up. I've done some searching, and the only place I've found "uprated" injectors for a Cooper was on eBay. Naturally, I'm a little suspicious.
Originally I know that intake, chip, header and cat back will get me close at the crank. I am still thinking of port and polish the head. A light weight flywheel, and crank pully. (yes, I know it won't do much on the dyno but will help out in the real world)
I don't think there is anything "unrealistic" about an MC with 200hp. (with a much larger budget of course)
You won't get there with just a chip and a cam.
But open up the bottom end to lightweight fordged pistons, light weight rods combined in a bit stroked and a higher compression. Then open up the TB and exhaust along with a nice cam to make the best of it and software to mesh.
I think its very attainable. A bit extreme, for everyday use. But we will see a 200hp all motor MC.
Connectors are easy to modify! You just have to know what signals the wires are sending.
Individual throttle bodies on this Cooper. They put the 'S' bonnet on this Cooper that allows it to breath throw the scoop.
At the risk of sounding like an idiot, can I ask what that does?
What is the effect on the engine life/other parts and performance? How much does it cost?
I actually want more info on this setup. Brings back memories of Webers. (carburators) Actually, replacing the FI with 4 Webers would be really cool, and the sound would be incredible!
Steve
Better breathing. Instead of the air going through 1 TB, and down the intake runner to the cyliders, each cylider gets it's own freash air.
Steve
Steve
