best place to pick up 12v ign live
Ok so i hate having leads trailed about with a passion so sat nav etc needs to be hard wired in
previous cars I've just picked up a 12v feed from back of fuse box and well thats it simple
but the r56 having can-bus and all this **** i don'f fully understand yet the question is whats the best place to pick up a normal ignition live on an r56 without causing other issues?
thanks in advance for advice
It's the same as any other car. Use an Add-A-Circuit to tap power from a fuse. Choose a fuse that is switched with the ignition.
https://www.northamericanmotoring.co...not-fuses.html
The green wire on the IBD2 port provides 12 volts with ignition on.
The red and blue wire at the opposite corner is 12 live all volts live all the time.
Th purple wire with white stripe next to the green wire is < 8 volts with ignition on.
Ta87
06-22-2021 04:51 PM
13WSCRJCW
08-03-2018 08:08 PM
