Cooper (non S) Modifications specific to the MINI Cooper (R56).
Ok this might sound dumb but can u blackout beltline with plasti-dip?
Old Jul 18, 2009 | 10:32 AM
Ackercracker's Avatar
Ackercracker
is it dumb to do? cuz i bought the blackout tape for the beltline but i dnt like it so i returned it? so is it dumb if i spray the beltline with plasti-dip? i will tape it off really good so theres no over spray? PLS HELP LOL!
Old Jul 18, 2009 | 10:45 AM
drewstermalloy's Avatar
drewstermalloy
There are a few threads on here of people doing it, but you'd have to tape it all for each coat. The Plasti-Dip makes a rubber like film, and if it touches the tape, it'll rip off when you take the tape off. So basically you'll have to spray one coat on it, and rip the tape off as soon as you can. It's possible, and it looks good, but it takes lots of time.
Old Aug 24, 2012 | 11:52 AM
Drakosd's Avatar
Drakosd
I sprayed Mine. Check gallery. Don't worry about the tape so much. Tape to protect the window above the beltline and Leave a 2" gap below the beltline before the tape. If done correctly you will be spraying ONTO THE PAINT as well as the beltline. Spray several layers to make a thick surface. (about 5 layers) Once you lift the tape on the lower half it will peel up a little on the car paint section. (A fresh waxing before you spray will make this even easier.) Lift the Plastidip on the bottom (on the cars paint) and remove it. It will peel off the paint and leave the Beltline behind.
Because there is a gap between the beltline and the cars paint, it will not connect the Plastidip, and thus make it easy to get an even coat. The Plastidip will then peel right off the paint.
Many people are afraid to spray this stuff on their car because its "like" paint. But its not. No worries, if you overspray a little it come right off. No need to tape off like its in a paint booth.
-ALSO, doing it this way (leaving a gap FOR oversrpay) keeps you from having to lilft the tape between each layer.
Old Sep 6, 2012 | 09:01 AM
rambukero89's Avatar
rambukero89
I also did mine last week.! Super easy.!
Old Sep 6, 2012 | 12:37 PM
05r50's Avatar
05r50
Mini is blacked out with this. http://www.outmotoring.com/mini-coop...tline-kit.html
Pretty easy tape. Works well. lasts long time
Old Sep 16, 2012 | 12:21 PM
albi's Avatar
albi
I Also used this and am happy with results. You need a sharp modelling knife for when you reach the edges and should take your time.
I did this by my self but 2 pair of hands would have been easier. I used the blunt edge of the knife to move the rubber trim and tuck the vinyl wrap under as I went along. (there is not much tape spare if you make a mistake so I bought 2 sets).
Good luck
Old Sep 16, 2012 | 02:50 PM
buzzsaw's Avatar
buzzsaw
I used 3M 33+ electrical tape for the beltline and it was an easy, inexpensive, durable and quick installation. Did consider plasti dip but the thought of all that masking made the decision to use tape more convincing.
Colt45Magnus
Aug 27, 2024 05:03 AM
Filmy
15
Jun 6, 2023 06:27 AM
patsum
26
May 29, 2021 06:29 PM
tag1260
Tires, Wheels, & Brakes
Sep 10, 2015 08:57 AM
Panik
Sep 9, 2015 08:36 AM
