Looking for a Fuel Tank sending unit leak solution
Old Dec 14, 2015 | 08:50 PM
Mochaman's Avatar
Mochaman
First off, I am new to the group. I own a British spec Mini for past 8 years. Bought from a friend stationed in England.
My issue is the Fuel Sending unit gasket started leaking out when the car sat for some time. Fixed it, rebuilt fuel system, just finished rebuilding the carb.
Changed the Fuel Sending gasket and it sat for one week with fuel in it. I was waiting on final parts to come in. Started pissing fuel again.
I don't think the gaskets that Minimania sell can handle the ethanol in our fuel.
Has anyone used an O-ring or another brand that works better in this location?
Mochaman
Old Dec 14, 2015 | 10:48 PM
MINIdave's Avatar
MINIdave
a light coating of Permatex Gasket-Cinch might insulate it from the ethanol, or even a light coat of RTV.....
That said, mine doesn't leak - it's just a factory style cork gasket.
Old Dec 16, 2015 | 11:07 AM
Mochaman's Avatar
Mochaman
I don't have a Cork gasket, mine was originally a rubber gasket. Although I may have to try out the cork gasket.
I did find a rubber gasket made by Viton that says it won't be ruined by ethanol. I found this when doing some in depth Google Searches, found a website discussion with MG vehicles. Someone in the discussion said this particular size made by Viton will fit in Mini gas tank. I ordered the gasket and should see it by next week. Will let the group know if this is correct size and the actual part number when it comes in.
Old Dec 16, 2015 | 12:14 PM
DaGriz's Avatar
DaGriz
Ethanol is the devil.
Old Dec 16, 2015 | 01:11 PM
Capt_bj's Avatar
Capt_bj
if the gasket that leaks in intact you have a template
go to any autopart store and buy a sheet of a good gasket material of choice ... one suitable for a fuel application of course. Should cost only a few dollars.
Get your pen out and trace ... then get the scissors and exacto knife out. I've done this several times .... works just fine if you are good at arts and crafts . . .
I would not try for a head gasket obviously, but fuel pump (original on the block), thermostat .... easy!
Old Dec 16, 2015 | 06:39 PM
MINIdave's Avatar
MINIdave
I would normally agree with Capt BJ, but cutting those tiny screw holes out in a cork gasket with an Xacto knife would be really tough. Viton would be easier, but what I do to make the holes is make a punch - get a scrap piece of brake line and sharpen the end then punch the holes out. Works a treat
Old Dec 17, 2015 | 07:00 AM
Mochaman's Avatar
Mochaman
My fuel sender gasket does not have the holes, it is just a solid piece of rubber. So much easier to cut out.
Old Dec 17, 2015 | 09:15 AM
Capt_bj's Avatar
Capt_bj
wanna just try a different vendor?
I use these guys a bit ... no complaints
http://www.7ent.com/products/rubber-...t-ara1502.html
Old Dec 21, 2015 | 05:29 AM
Mochaman's Avatar
Mochaman
I was able to find one from a website called Little British Car Company. Horrible website to maneuver on, but they did state the rubber seal was ethanol resistant.
I have the new seal now, wanted to go find a sheet of rubber gasket material to be able to make my own if needed. Nothing at Oriely's even came close to the thickness of this seal.
Will have this installed over the Christmas holidays and hopefully get the Carb tuned up since I rebuilt it.
I also bought the Marine version of Stabil. It is supposed to work better for open vent gas tanks. It is specific to ethanol and the issues with water absorption.
Trying to find non Ethanol gas in my area of Dallas.
Old Dec 21, 2015 | 05:45 AM
Capt_bj's Avatar
Capt_bj
be careful with eth' free vendors, I had a bad experience.
around here the guys who sell e-free are all small
I tried a tankful of 'premium' and my car ran like crap ... same way it did the one time I put in mid-grade.
I went back to Shell premium and everything returned to normal
sounds to me like the e-free guy was low balling the octane content .... which does not matter in a weed eater or lawn mower.
p.s. I have not replaced a single line gasket or seal in 10 years due to ethanol damage. When replacing a part, yes ... but not due to deterioration. I remember to toss in a treatment I get from Eastwood about 1 fill in 3.
Old Dec 21, 2015 | 06:34 AM
Mochaman's Avatar
Mochaman
I have owned my car for 8 1/2 years and have never had issue with it until recently. It has sat for months at a time when I went to Afghanistan several times. Not one issue. Then suddenly the Tank seal turns to mush and pisses gas out. Changed it, same thing. Carb varnishes up and quits working.
Bad gas at a Shell station?
Old Dec 21, 2015 | 10:56 AM
mk1leg's Avatar
mk1leg
can you give details of year and model as If a Van/estate or saloon the saloon sender is held tight by a twist lock system the van/estate uses a bolt system the cork gasket is for bolt system the rubber is for twist system on saloons
Old Dec 21, 2015 | 12:07 PM
Mochaman's Avatar
Mochaman
Mini 1000 Saloon. It is the twist lock type with the rubber gasket.
Old Dec 21, 2015 | 03:20 PM
Capt_bj's Avatar
Capt_bj
with the twist on
it would probably be a good idea to lube the gasket so it slides during the tightening.
A little silicone lube for o-rings would be what I'd try ..... Just like the o-ring on the MINI oil filter, failure to lube it can result in a crack or break you can't see until you remove the entire unit .... AFTER it spews all over your engine bay! or in this case ... the boot
Old Feb 18, 2016 | 03:11 PM
mikeyr's Avatar
mikeyr
Old thread I know but I am the new guy and I just went through this in the last 2 weeks.
I bought a mini that the previous owner used RTV to put the sending unit on, he put too much and ended up with RTV in the fuel tank. I would drive down the freeway and car would stall as if fuel starved, a few minutes later would run fine, tried a new fuel pump and still no go.
Finally found the RTV in the tank and cleaned it out, went to Moss (they are local to me) and bought a cork gasket, no issues with it and no leaks.
Here is what I found in the gas tanks, so my point is you use RTV, use it sparingly, dont use too much.
Old Feb 18, 2016 | 03:26 PM
mk1leg's Avatar
mk1leg
never use a sealant as it might get sucked into pipe and block it and then you will need to renew pipe from front to rear....
Aug 16, 2016 01:37 PM
sempdog
Nov 6, 2015 09:56 AM
Nov 1, 2015 12:03 PM
Nov 1, 2015 12:02 PM
Nicefeet
Nov 1, 2015 06:43 AM
