Is it cheaper to own and maintain a classic than a MINI?
Anyone care to break it down for me? I'm trying to set aside money for upcoming repairs and predictable issues on my 03. It occurs to me I maybe should have gone with my original desire-a classic. Every so often someone's selling one around here. Are the classics (thinking 80's, fuel injected) all that rough to maintain after a decent restoration?
Depends on how you plan to use the classic.
First question: can you spin a wrench? For all repairs or is there a level beyond which you need to get a mechanic? If you plan to use it as a daily driver, then you really MUST have access to a local shop for the repairs you can't (or won't) do in your garage. Things WILL break, always at the worst possible time, and when they do, you'll need to go on a site like MiniMania or GBCarparts and order supplies, which can take a week or so to arrive. Once you have the supplies, can you swap out a clutch? Work on electricals? Disassemble the front end suspension, swap out a CV boot and re-pack the bearings with grease? Cram yourself under the car to swap out seals? All this and more are things you'll be able to look forward to.
All that said, only a select few shops will generally work on classic Minis, so get that set up ahead of time BEFORE you buy a classic if at all hmanly possible. There's no way I'd have a classic as a daily, primary driver unless I had access to a skilled mechanic a phone call away...
Second question: do you have a backup car? Like I said, something failing in a classic generally means ordering parts and wrenching them yourself. It's bad if your classic is your only way to get to work in such an event.
Honestly, every repair I've done so far has cost me less than $100, with the exception of a full set of new wheels and tires I just put on ($800 - ouchies - but SO worth it), but that's because I did all my own mechanicals, or had friends who knew their way around the stuff I conldn't handle help me out. that's great IF you have that access to helpful people, but again, it's probably not the best scenario if the car will be your daily driver.
Honestly, I think *I* have the best-case scenario: a 2005 MINI for my daily and winter driver, and my classic for sunny days and any time I want to drive something stoopidly fun. if I have to put the classic up, as I do for a few months in the winter, or for a few weeks while I suss out a repair, I have NO stress about it.
on
Go on mini mania and look at both sides. Pretty much similarly high in parts cost. Your run of the mill mechanic really doesn't want to work on either of them so it depends if you can find good labor either way. The local MINI dealer here charges 106 an hour. Correct me if I'm wrong but I thought fuel injection didn't come about till around early 90s.
Cost wise a classic probably less $, but time wise, more is spent repairing the classic.
My 03 s currently has 196,000 miles on it and has only been of the road for 2 days due to repairs. (replaced supercharger at 191,000 miles) I expect to have it off the road for another day or so when I replace the clutch in the next few months. Total cost so far for repairs and gen maintenance on the 03 is probably around $1000 to $1500.
My classic since we got it about 4 years and almost 50,000 kilometers ago has been off the road due to repairs for probably 4 months total, but probably only costing ~$300 to $500 total for the repairs.
So if you need something reliable I would go w/ the MINI, if you can handle cheaper and have other means of transportation then you might be able to swing the classic. I have saved ALOT of money because I do all the work on both cars myself. example - new supercharger at dealer $1800 to $2800 - did it my self for a total of $500.
The classics (especially the efi ones) can be very reliable, once I got the bugs worked out ours has been working great. It is my wife's daily driver (she sold the reliable honda pilot )
Good luck
Nik
Good luck
Nik
Stick with a carbed classic either way... those injected models always have a TON of threads on the UK forums asking for diagnostic and repair help. Carbs, by comparison, are dead-simple. Based on the oxygen sensor port on my header and some redundant wiring under the hood, I think my car (a '92) began its life as an injected model and was down-conveted back to carbs. Thank God.
I thought only 25 yr old cars could be grandfathered in under emissions standards here. When I realized I couldn't afford a new MINI, I thought going after a discontinued British model would be the answer to high cost, but sadly no. I'm not enough of a mechanic to do major work. I have replaced some parts like starter motors and pumps on older American cars, but I can't say it was fun-just a necessity.
on
Here's an example from local Craigslist ( hey that's my oil supplier in the backgound!). Actually, this is a very good deal wiht Nav and roof if it checked out.
2002 MINI Cooper Hatchback 2D - $7200 (Acton, MA)
Reply to: sale-n23jg-1092874957@craigslist.org [SIZE=1][[/SIZE][SIZE=1]Errors when replying to ads?[/SIZE][SIZE=1]][/SIZE]
Date: 2009-03-26, 11:29AM EDT
Fantastic little car with a BIG car feel. When seats fold down in back, storage space is bigger than most other regular sized cars.
Mileage is really great. With gas prices on the rise again, you will make out nice with this car. Great for COMMUTING. This version of the Mini gets better mileage than the S (turbo) version.
STATS 4 cylinder 1.6 liter engine, front wheel drive, 5 speed manual for better mileage, AC, power steering, power windows, power door locks, tilt wheel, cruise control, AM/FM stereo, single compact disk, NAVIGATION system built in, dual front air bag, front side air bags, 4 wheel ABS system, moon roof, new front tires, alloy wheels.
7 brand newoil filters included
Miles per gallon: averages 33 MPG by my own calculations
101,800 miles
The car is in excellent shape and has had all it's checkups. It just had an inspection and only needed new tires in the front, which I replaced. Everything is in good working order. Give this little guy a new home!!
Thanks, Tr6drvr. That's actually what I did already. I bought a high-miles 03 that was taken care of. Now I'm laying out long term maintenance and repair plans/projections. My original desire was a classic mini, and it's a die-hard wish. I just saw an ad for a nice looking '80 Leyland...
Living close to the Bruce Weiner Microcar Museum doesn't help.
Last edited by Stanislaus; 03-31-2009 at 04:43 PM. Reason: wrongly addressed to ImagoX-fixed.
Anyway, here's that Leyland:
http://atlanta.craigslist.org/cto/1091106384.html
The color is so right on, the name is so beyond lame.
Another local listing:
http://atlanta.craigslist.org/cto/1061009706.html
Let me know if you need me to test drive anything before the sale!
...And furthermore:
http://greenville.craigslist.org/cto/1109380222.html
This one is tempting as it is almost on the edge of affordable.
...And furthermore:
i have owned many classic sport and muscle cars 60's & 70's era--a friend was going to sell his modern nissan sedan to buy an old vw karmangia--this vw was to be used as his daily driver--i said to him that the secret to driving an old car is to own a new one too
on
...And furthermore:
