Chicago MINI Motoring Club The Chicago MINI Motoring Club Forum. Visit our club site at www.chicagominiclub.com
Shop for a Clutch Job
Old May 3, 2019 | 10:57 AM
Frozer860's Avatar
Frozer860
I have an R53 that has about 95k on the clock. The clutch is starting to slip. Looks like it is quite the job to do on your own, and unfortunately time is something I don't have. Anyone have an shops in the Chicago area they can recommend for a clutch job? I an in the NW suburbs, so closer to their would be great? If anyone recently got their clutch replaced, I am curious to see what the cost was. I know the labor itself is the killer.
Old May 4, 2019 | 01:03 PM
ernesto's Avatar
ernesto
Coordinator :: Chicago MINI Motoring Club
My favorite place is Import Service Center in Glenview
http://www.glenviewimportservice.com/
Been going there for many years..
Old Jul 18, 2019 | 02:26 PM
thevastdifference's Avatar
thevastdifference
Same. Got me an R53 with 150k. I'm looking at:
http://www.mobileoneinc.com/Mobile_One_Inc/Home.html
as suggested by a friend who's been taking his mini there for years. I used to go to Hubbard Woods, I know they are referring old customers to a shop near their old location, but I forgot the name of the place.
Old Jul 18, 2019 | 03:39 PM
Frozer860's Avatar
Frozer860
Thanks guys for the suggestions! Are you at 150k on original clutch?
Old Jul 18, 2019 | 03:53 PM
thevastdifference
Yes.. 150k on the original clutch.. I want to say that I started noticing the slip around 125k, but I didn't have the time to work on it and it wasn't too bad. I could probably get by another 25k on it if I really needed to!
Here are some other suggestions I've found:
http://www.thewerkshop.com/
And I noticed Mini Mania Posted these links (Did not take a look yet) https://new.minimania.com/article/31...ners_and_Shops
https://new.minimania.com/Mini_Coope..._for_your_Mini
A buddy of mine owns this shop, but I don't know how he is with MINI's yet:
https://www.tf-works.com/engine-transmission/
Old Jul 19, 2019 | 07:22 AM
cooper48's Avatar
cooper48
Parts (clutch disc, pressure plate & flywheel) run around $350 for a Valeo kit. You're right in saying that it's a bunch of work. I just installed a clutch in my R53 and it's pretty involved (FESM, dropping the subframe, removing the transmission and a bunch of other parts). However, it's a GREAT way to learn a lot about how your Mini works. I'm lucky enough to be retired and have a Mini that's not my DD so repair time is not really a factor. I worked on mine a little each day for about a week. I believe having it done is close to $2,500 because there is a ton of labor involved.
Old Jul 23, 2019 | 07:18 PM
thevastdifference
I contacted the werkshop, but they said they cannot put a warranty on the labor if they use customer purchased parts. Is this usual for a lot of garages? I don't mind about not having a warranty on the part, as long as the labor has some sort of guarantee.. Does any shop do that? Waiting on replies from other shops at the moment. Will update.
Old Jul 23, 2019 | 07:21 PM
cooper48's Avatar
cooper48
Parts markup can be 100%. That's the shop's issue ... if you buy the part, they can't mark it up. It has nothing to do with a guarantee which by the way comes from the part manufacturer not the repair shop. Find another shop.
Old Aug 4, 2019 | 01:35 PM
thevastdifference
Gotcha. So thewerkshop.com is out of the question then.
So far the parts I have on hand are the Valeo Clutch Kit and rear main seal.
Any other parts I might want to replace while I'm at it? I'm looking at these three shaft seals:
Shaft Seal 26x40x7,1 $22.05 23117518633 https://parts.miniofkennesaw.com/pro...117518633.html
Shaft Seal 36x58 $40.40 23117518638 https://parts.miniofkennesaw.com/pro...117518638.html
Shaft Seal 40x62 $43.51 23117550058 https://parts.miniofkennesaw.com/pro...117550058.html
Necessary?
Old Aug 4, 2019 | 02:14 PM
Frozer860's Avatar
Frozer860
Based on my research, check the rear main seal and replace while you're there.
Old Aug 4, 2019 | 05:05 PM
cooper48's Avatar
cooper48
+1 Frozer860 ... The rear main seal is right there once the flywheel is removed. Easy to replace at that time (even if it's not currently leaking). Shaft seals are also easy to access at that time so maybe not a bad idea to replace them also.
Old Aug 4, 2019 | 08:14 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If doing a clutch job you will have the front subframe out so it is the best time to upgrade the front control arm bushings to powerflex. The stock ones wear out every 40k miles and the PF won't wear out again. Since the subframe is out it cuts the labor down to an hour or less to replace them.
https://www.waymotorworks.com/powerf...shing-kit.html
And yes the Valeo kit is a good option for replacement as it's cost effective and reliable.
https://www.waymotorworks.com/valeo-...l-kit-r53.html
Old Aug 4, 2019 | 11:36 PM
Scudder44's Avatar
Scudder44
Consider changing the input shaft seal on the trans and the release bearing shaft/slider. Yes to doing the axle seals while the drive shafts are out. Front rear control bushes are a must do too as WMW says. Mind that the flywheel bolts are torque to yield and must also be replaced.
Old Sep 16, 2019 | 12:25 PM
thevastdifference
Gotcha, I already replaced the control arm bushings to the purple powerflex a few years back. They're great!
Took my mini to a shop in Glenview IL today, http://mobileoneinc.com/ . Originally quoted around $800, but got back to be with $120/hr for 11 hr service, with an additional hour for the rear main seal? Still not a bad price I think. I supplied the Valeo clutch & flywheel as well as the rear main seal. Hopefully all goes well, considering the age of my R53 and some lines being quite old and corroded @_@
Old Sep 19, 2019 | 11:03 AM
thevastdifference
I'm in a bind.. the shop has my car, apparently the rear main seal that i had delivered is not OEM and my guy doesn't to use it since it won't be under warranty. Current rear main seal is not leaking. It will take a few days to get ordered in. I need my car to be done by EOD tomorrow.. do I risk staying with the exiting rear main seal or totally worth it to wait for an OEM one to be shipped??? I'm calling local service shops around to see if they have one in stock now..
Old Sep 20, 2019 | 08:24 AM
Frozer860's Avatar
Frozer860
What RMS did you get. Victor Reinz?
Old Sep 20, 2019 | 11:28 PM
thevastdifference
a fel pro *slaps forehead*
Old Oct 7, 2019 | 03:31 PM
Frozer860's Avatar
Frozer860
Just an update. I did the job myself. Took about 16 hours total. That includes changing Crank position o ring, oil pan gasket, RMS, and other broken bolt's and such. Pretty straightforward but very time consuming.
PelicanParts.com
Jan 17, 2017 10:34 AM
PelicanParts.com
May 10, 2016 09:39 AM
PelicanParts.com
Jan 7, 2016 09:48 AM
steaming79
Northern California
Sep 13, 2010 11:56 AM
