M7 speed /max-boost™ octane booster & fuel system stabilizer
MAX-BOOST™ OCTANE BOOSTER & FUEL SYSTEM STABILIZER
http://www.m7tuning.com/max-boosttm-...oz-bottle.html
Royal Purple’s new Max-Boost is a high performance octane booster and fuel treatment for racing applications that increases gasoline octane, reduces emissions, and enhances engine performance while stabilizing fuel.
Formulated with MMT, Max-Boost delivers the best octane enhancement to help eliminate engine-damaging detonation, pre-ignition, and pinging or knocking from low-octane gasoline. Max-Boost is the best fuel system stabilizer for anyone looking to significantly boost engine performance and efficiency.
Max-Boost fuel system stabilizer is formulated for racing engines equipped with carburetors, port fuel injection and direct injection, as well as turbocharged, supercharged and nitrous-injected engines.
Max-Boost is safe for use in leaded and unleaded gasoline, and alternate fuels like gasohol, reformulated gasoline, and all ethanol blends. Our premium fuel system stabilizer is also safe for oxygen sensors and catalytic converters.
Ready to outperform?
MAX-BOOST PERFORMANCE ADVANTAGESFormulated with MMT, Max-Boost delivers the best octane enhancement to help eliminate engine-damaging detonation, pre-ignition, and pinging or knocking from low-octane gasoline. Max-Boost is the best fuel system stabilizer for anyone looking to significantly boost engine performance and efficiency.
- Reduces engine knocking and pinging
- Raises octane rating up to 30 points or 3 numbers
- Restores power and fuel economy
- Cleans deposits from fuel injectors
- Reduces power loss due to knock-retard in computer controlled vehicles
- Replaces lead additives for protection of non-hardened valve seats
- Stabilizes fuel
One can of Max-Boost treats up to 25 gallons of gasoline. Pour entire can into tank before fill-up. Clean immediately if spills occur, as Max-Boost can permanently stain painted surfaces. Do not expose liquid to direct or indirect sunlight. Be sure to replace cap after can has been emptied, and dispose of properly.
PLEASE NOTE:Max-Boost is a racing formula and is not street legal. Please consult Royal Purple’sautomotive technical support department for more information.
07-16-2020 12:54 PM
Powershift
08-16-2015 05:14 PM
