3rd Gen FAQs 3rd Gen Common Questions & Answers!
Dynamic Damper (DDC), Tools Needed to Dissasemble.
Old 05-20-2018, 11:33 AM
TVPostSound's Avatar
TVPostSound
TVPostSound is offline
Dynamic Dampers do not have the 7mm Allen head on the shaft to hold while loosening the top hat nut. There is a 10mm 6 point hex at the top of the shaft.
Here's my solution.
Besides basic wrenches and sockets, you will need these specially tools:
18mm Strut Nut Socket from ECS:
https://www.ecstuning.com/b-schwaben...3046sch01a-01/
10mm Brake Bleeder Wrench:
Amazon Amazon
Must have:
Spindle spreading tool:
https://www.ecstuning.com/b-schwaben...-tool/scw3435/
Pics attached!!
ECSTuning (06-11-2018)
Old 05-20-2018, 11:40 AM
TVPostSound
Optional,
Crescent 18mm X6 passthrough socket with 10mm 1/4" drive socket and extension.
Old 06-09-2018, 09:16 AM
TVPostSound
Just finished the front springs, here's a trick for spreading the spindle:
Insert the spreader in the opening just below the cross bolt hole, if you try the top part
the strut tab will catch on the tool.
Leave the top of the strut bolted in, push the rotor down with your foot, and bam!!!
Also do not fully tighten the top strut shaft nut until after you install,
you will need to turn to top hat to position, and turn and hold the shaft
to line up with the electrical connector.
The ECS tool and 10mm brake bleeder wrench worked perfectly!!
DO NOT LET THE SHAFT TURN MORE THAN 1/4 TURN.
USE OF AN IMPACT GUN TO SPIN THE NUT OFF WILL RESULT IN A
DAMAGED $375 SHOCK.
Of course, there will be a follow up saying, "I used an impact with no problems"
That would be luck.
In my previous career, as a tech, Ive ruined many shocks with impact guns
trying to beat the flat rate!!!
BTW, No spring compressor required to install new spring, just push down and start the nut!!!
Old 06-11-2018, 02:28 PM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Great!
Old 04-11-2019, 12:54 PM
RLM's Avatar
RLM
RLM is offline
I just used a large mallet on the upright. a few hits and it dropped. no spreader tool required.
DAMAGED $375 SHOCK.
I used an impact to disassemble and reassemble. Have put more than 30,000KM on the car since with zero issues. the reason is because the 10mm hex is not very strong. I initially tried to use a 6pt socket on it inside a custom made 18mm extra deep socket with an opening. The hex deformed very quickly. tried a wrench while putting a small cutoff of round rod in the electrical plug to resist deformation, Nope, still deformed. Zipped it off with an impact after that (shaft didn't move within shock) then zipped the nut back down after the new spring was in.
Old 04-14-2019, 01:33 PM
2017All4's Avatar
2017All4
2017All4 is offline
Super Moderator
Testing the thread.
06-01-2017 10:38 AM
Car Care Products
06-01-2017 10:37 AM
06-01-2017 10:27 AM
etl330
04-09-2014 07:40 AM
Mrdi
04-08-2014 06:07 AM
Quick Reply: Dynamic Damper (DDC), Tools Needed to Dissasemble.
