2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Question about jacking up the F60 Countryman
Old Nov 12, 2019 | 07:50 PM
uzun's Avatar
uzun
Hi guys, I am thinking about doing a front to rear tire rotation on my 2019 JCW F60. If I were to jack up high enough under the front jacking point, would the rear wheel also lift off the ground? That's what I do on my R56 but I am not sure if this procedure would work on the F60. Perhaps someone has already tried this on the F60.
Old Nov 12, 2019 | 08:37 PM
1RavingLunatic's Avatar
1RavingLunatic
Honestly, I'm not sure, but it wouldn't matter if you used jack stands...which you should!
Old Nov 12, 2019 | 09:31 PM
Fly'n Brick's Avatar
Fly'n Brick
Most of the old wisdom has vanished into the wind. Here's a MINI jacking lesson from a long gone poster. His blog is still worth a visit. Click on the link and scroll down to "How a stud lifts a MINI". My 'stud' has dozens of jack tracks on both sides.
https://www.blimeycabrio.com/2007/04/
Old Nov 12, 2019 | 10:16 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Done this on the R60 which is obviously a bit different although similar in size/weight. Really not a comfortable situation with my floor jack as the front gets too high to get the back far enough off the ground. Since my rotation includes changing to seasonal tires it isn't an issue to move the jack. With a high lift strong floor jack you are probably ok and some stands.
As for the F56 similar to the R56 in that the whole car lifts up on one side and tire rotation is fast.
Old Nov 13, 2019 | 01:46 AM
Scudder44's Avatar
Scudder44
Stands always! When rotating tires you should go front to back and diagonal so lifting one side alone is counter productive.
victoryrider
14
Mar 10, 2023 01:25 PM
corliss hale
Jun 18, 2013 10:24 PM
toolazyforalogin
Nov 5, 2008 11:23 AM
maddog
Jan 9, 2008 06:27 PM
KC MCS
Oct 12, 2006 01:59 PM
