2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Aftermarket shocks/coilovers
Old Apr 23, 2019 | 05:14 AM
F56-JCDub's Avatar
F56-JCDub
So if you have the MINI options that control suspension and steering in the different modes, how is the suspension affected if you switch to aftermarket shocks and/or coilovers? I guess, the real question is: how does MINI control the suspension? Are there special shocks that have electronically controlled valving? Please school me on this. I know nothing and am curious about how this works.
Or lowering springs as well... I'm wondering what this does to the factory dynamic suspension system?
Old Apr 23, 2019 | 04:43 PM
F56-JCDub's Avatar
F56-JCDub
I did some searches, and basically, there is some sort of electronic solenoid or actuator of some sort that controls the Dynamic Damper Control. So if you switch our your shocks with this technology, with standard technology shocks/struts then you lose DDC. It does seem that some aftermarket shocks do have DDC shocks that are compatible with OEM systems, but not sure yet if there is one for the MINI systems.
Old Apr 24, 2019 | 03:33 AM
F56-JCDub's Avatar
F56-JCDub
Looks like KW makes them for some MINI applications, but they don't specify an F60 JCW. This might be a nice upgrade.
Old Apr 24, 2019 | 04:55 AM
Medarlin's Avatar
Medarlin
I just chatted with KW online, none of their dampers will maintain the DDC function of the F56 MINI.
I am pretty certain if you want to keep the DDC functionality, you'll need to stay with MINI original equipment dampers.
You could install lowering springs on your car with out any issues with the DDC.
Old Apr 24, 2019 | 05:01 AM
F56-JCDub's Avatar
F56-JCDub
Nice. Thanks for following up on that.
Old Apr 24, 2019 | 05:24 AM
Medarlin's Avatar
Medarlin
I've been wondering the same thing myself, but at 60K miles on my F56 S and no signs of them losing effectiveness, I have no reason to replace the original dampers. Besides, I love the DDC functionality and use it a lot.
Old Apr 24, 2019 | 06:27 AM
F56-JCDub's Avatar
F56-JCDub
Same here, and I'm only at 20K miles on my F60. I just like to think and plan ahead. Unfortunately, I'm usually ahead of the market and have to wait a long time.
Old Apr 25, 2019 | 02:48 AM
Madman23's Avatar
Madman23
How i s the dynamic suspension? I have always wondered that.
Old Apr 25, 2019 | 04:02 AM
F56-JCDub's Avatar
F56-JCDub
I think it is great. Green --> Normal super subtle difference. Sport mode is much tighter suspension and heavier steering. Because of the way DDC works in Sport mode, I pretty much don't feel I *need* a rear sway bar. The handling is very go-cart in this mode. That also means a harsher ride in Sport as compared to Normal or Green modes.
Old Apr 25, 2019 | 11:26 AM
victoryrider's Avatar
victoryrider
Ditto what f60jcw said and double ditto on Sport being harsh ride. Sport is very stiff, I thought it was the run-flat tires so I switched to non-run flat Continental DWS, it's a little better but still very harsh in sport mode.
Case1220
Mar 28, 2017 06:36 PM
PAWS
Jan 14, 2017 03:46 PM
johnD
Dec 3, 2003 07:23 AM
dpayne1
Suspension
Jan 9, 2003 07:32 PM
