2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Check Engine light every time the temps drop below 15 degrees Fahrenheit
Old Jan 14, 2019 | 10:01 PM
MINIMegatron's Avatar
MINIMegatron
I have a 2018 S All4 and everytime the temps get extremely cold outside the car gets a check engine light. Nothing changes in drivability or any noticeable.
Ideas?
Old Jan 15, 2019 | 07:07 AM
jourgenson's Avatar
jourgenson
That happens to me as well with my 2017 All4. Several times I have taken it into the shop when it happened. I think all they do is send the computer info to MINI, do an oil change, and reset it. They made it sound like it doesn't happen everywhere and may have something to do with the temperature and humidity affecting the fuel injection.
Old Jan 15, 2019 | 09:36 AM
Blu_lite's Avatar
Blu_lite
Not to alarm anyone but just keep an eye on it and check the codes every time. My issue was a cracked fuel injector.
I had a similar issue with an R56. Below 10 deg C it would give me a CEL. Pulled the code it was misfire on cylinder three but would be fine the next time I start the car in warmer temps. Swap coil packs, waited for a cold day, CEL came on same misfire code on same cylinder. Got new spark plugs same issues same cylinder. Thought it was intake manifold clogged with soot and residue, walnut blasted no help. Finally changed the fuel injector and that fixed the issue.
mattjewell
Nov 20, 2014 01:29 PM
Scooter162
Jan 9, 2010 12:34 PM
naffets
Jan 15, 2008 12:15 PM
greatgro
Dec 2, 2003 01:22 PM
