R60 Is there a way to open the R60 rear hatch door from the inside?
Old May 5, 2026 | 01:17 PM
ski.dive's Avatar
ski.dive
Old May 5, 2026 | 02:17 PM
Raymo2u's Avatar
Raymo2u
There is a button right under the hood latch for it
Old May 13, 2026 | 10:11 AM
harleydood's Avatar
harleydood
I have a 2011 R60. That would be a negative on the emergency latch.
I replaced my latch 4 years ago while it was still (barely) working. I would have to pull the handle 4 or 5 times to get the hatch open. Doing a little research I discovered that replacing the electric latch release with the hatch open takes about 15 minutes. Conversely, if the hatch is stuck closed it becomes a major operation. Ergo, I got when the gettin' was good, went down to the dealership, purchased the part and changed it myself right there in the parking lot in just a few minutes. My strong suggestion is that if there is any life left in that latch, get the hatch open and leave it open until you can replace the part.
D
Old May 14, 2026 | 10:58 AM
y8s's Avatar
y8s
D
Which part did you replace? the handle itself? the latch in the bottom of the hatch?
Old May 14, 2026 | 02:18 PM
harleydood's Avatar
harleydood
Not the handle. The latch. I have also seen it called "Actuator Latch" or "Trunk Actuator Latch."
D
Old May 20, 2026 | 06:55 AM
y8s's Avatar
y8s
#4 "Trunk Lid Lock"? mounted on the floor by the bumper?
I ask because mine does absolutely nothing quite often when i lift the emblem.
Old May 20, 2026 | 07:55 AM
harleydood's Avatar
harleydood
Yes, that is the part (#4). And you'd better replace it while you can still get that trunk open. 'Cause if that "actuator" fails 100%, getting the trunk open is a huge deal. Conversely, replacing the actuator with the hatch OPEN is a 15 minute affair.
D
Here2Go
Jan 31, 2025 12:16 AM
MiniConn
Jan 7, 2022 07:25 AM
geekd4d
15
Sep 23, 2019 11:08 AM
JPMM
Eastern Iowa MINIs
Jan 26, 2015 10:46 AM
Darksky
11
Aug 18, 2004 11:08 AM
