R60 Struts/Shocks replacement
Old Nov 21, 2023 | 08:38 PM
bystander's Avatar
bystander
Hello,
My 2013 countryman S started being very bumpy recently so it's in need of new shocks and struts. I heard the Bilsteins are a good brand and I found this on ECS tuning
https://www.ecstuning.com/b-bilstein...t/22-213709kt/
The problem is the kit doesn't include the strut mounts or the spring and I'm not sure what else the kit is missing that I might need. Is there a fully assembled strut kit that I can buy somewhere? I'm only interested in restoring the original ride quality so I'm not looking for any sport struts. I found this on rockauto but I'm not sure how reliable this brand is.
https://www.rockauto.com/en/moreinfo...15338&pt=15174
Old Nov 22, 2023 | 04:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My suggestion is NOT to get that RockAuto kit….
The set from ECS is decent, and will restore your factory ride. I would also suggest this kit be added to your purchase:
https://www.ecstuning.com/b-assemble...06772749ktkt1/
You will need a spring compressor for the job.
Old Nov 22, 2023 | 07:26 AM
bystander's Avatar
bystander
If I want to replace both the front and rear shocks/struts, do I need to buy two of the kits you linked? Also, I don't see any springs in that kit, is the idea to reuse my current springs?
Old Nov 22, 2023 | 12:43 PM
Yep those two kits.
You can reuse the current springs but inspect the rear springs as they are known to rust and crack on the back of the countryman. If they look new and no issues with rust you can reuse them.
If they are bad in the back PM you vin and i can get you the part numbers for the oem springs. MINI has a spring table that calculates the springs for Genuine MINI, all other springs are lowering springs.
https://www.northamericanmotoring.co...n-failure.html
Redmere58
R55 :: Clubman Talk (2008+)
33
Oct 30, 2021 03:04 PM
Frixos
May 20, 2019 08:08 AM
NomadMac
Suspension
Apr 3, 2017 08:14 AM
WildMini
Suspension
Apr 15, 2016 02:53 PM
roofaS
Suspension
Mar 5, 2008 11:12 AM
