R60 Break replcement advice
Old Apr 11, 2022 | 09:24 AM
tok282's Avatar
tok282
Hi im due for break and rotor replacement. Car is for my wife ,normal city driving . im looking at rockauto website and they have set of rotor and pads the brand is power stop z23, wonder if they are any good ? Or if anyone has recommendation of decent brand that will not break the bank and oem quality . Thanks evryone
Old Apr 11, 2022 | 10:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Get Akebono pads. Almost same as stock stopping power, MUCH lower dust levels, and wallet friendly. Then add the least expensive coated rotors for the full package.
Old Apr 11, 2022 | 10:47 AM
White_R60_JCW's Avatar
White_R60_JCW
I bought this complete assembled brake kit from ECS and it took about 3 hours to install with my daughter.
https://www.ecstuning.com/b-assemble...119804829kt12/
Old Apr 11, 2022 | 05:49 PM
tok282's Avatar
tok282
Thanks so much for ur recommendation guys, really appreciate ur help
Old Apr 12, 2022 | 09:34 AM
2014 MC's Avatar
2014 MC
I bought that kit for my daughters 2014 R60 and it worked out great. Came with replacement sensors and all. Was able to get it done fairly quickly with my sons help. Everything was there and fit well and happy with the results. Decided to replace the brake fluid at that time as well.
Old Apr 12, 2022 | 05:09 PM
tok282's Avatar
tok282
2014 mc you refering to the breaks from ecstuning or the rockauto?
thanks for your input!
Old Apr 12, 2022 | 05:12 PM
tok282's Avatar
tok282
Btw any of you have the torque spec for all bolts / nuts for this diy ?
Thank you!!
Old Apr 12, 2022 | 06:49 PM
2014 MC's Avatar
2014 MC
Powerstop from rock auto
Old Apr 13, 2022 | 05:31 AM
White_R60_JCW
Torque specs for an R56 which should be close to what you need. Sorry everything is in Nm here a converter https://www.convertunits.com/from/N-m/to/lb-ft
Old May 2, 2022 | 03:05 PM
tok282's Avatar
tok282
Im stuck cannot remove rear caliper bracket
did front break no issues , but…. The rear ??
Im stuck i dont know what kind of bolt that holds rear caliper bracket, looks like a male torx ? Base on what ive search its called e-torx ?? Does anyone know the size i need to remove the caliper bracket to replace the break disc ?
One site i looked says size 14mm etorx ? Is this the same size for the r60?
Old May 2, 2022 | 03:47 PM
2014 MC's Avatar
2014 MC
Yes, you need the e-torx and I can't recall what the mm size it was, probably 14mm sounds about right. I went to harbor freight and got a set that worked fine. And, the bolt is on there tight. I also needed the special tool to thread the piston back in while applying pressure (different than the front) due to the e-brake.
Old May 5, 2022 | 09:56 AM
J_Westy's Avatar
J_Westy
... looks like a male torx ? Base on what ive search its called e-torx ?? Does anyone know the size
E16
I got Zimmerman rotors and Bowa wear sensors from FCP Euro because of the total cost including shipping. But got EBC Redstuff pads from Mini Mania. Happy with the outcome
Old May 5, 2022 | 10:23 AM
We now have Brembo Sensors/Rotors/Pads built out for MINI. They are hard to find in the Gen 2-Gen3 MINIs as most distributors in the USA don't carry them. Also have R1 Concepts also just added.
Old May 5, 2022 | 11:40 AM
Jason Cornelius's Avatar
Jason Cornelius
Im Pretty sure i was able to use a regular 16mm on the etorx, this was on a 2014 R60s all4 and we used the power stop setup you are talking about.
Old May 5, 2022 | 11:45 AM
Jason Cornelius
torque specs from newtis
cloverasx
Tires, Wheels, & Brakes
18
Dec 4, 2018 06:52 AM
Pure87
Mar 19, 2014 03:46 PM
joesantoyo78757
Suspension
11
Dec 24, 2010 01:24 PM
farajauto
May 19, 2010 04:45 PM
06GRB
May 18, 2010 09:59 PM
