R60 Valve Cover Leak
Old Sep 20, 2021 | 10:58 PM
RockyMountainMarkgyver's Avatar
Valve Cover Leak
My mini needed a new valve cover due to PCV valve failure. I ordered a new valve cover (Aftermarket) and installed it. Now I have a large oil leak at the back of the engine, I can’t figure out where the leak is coming from there is a little oil on the front and rear left corner but nothing like the amount of oil I’m seeing. Any suggestions on what else to look for?
Old Sep 21, 2021 | 08:35 AM
CountryJim's Avatar
CountryJim
This is a timely question for me as well - I had a PCV failure last week, I have a Mini-OEM valve cover ($$$) arriving tomorrow. Is there a guide on order of bolt tightening & torque specs for the valve cover? RMM - maybe your torque specs or gasket sealing is causing the new oil issue?
Old Sep 21, 2021 | 08:45 AM
Torque Spec
I found the following torque spec on line of 10NM and this sequence.
When I idle the car I don’t see any leaks until I drive if for 10 min then there is about a cup of oil all over the back of the engine.
Old Sep 22, 2021 | 07:31 PM
Valve Cover Reinstall
So I reinstalled the original valve cover tonight and no leaks, I was talking to a friend and he suggested the possibility that the after market valve cover has a defective PCV valve in it and it’s not allowing the crank case gases to escape and creating to much pressure in the engine causing oil to blow out, which seems like a reasonable explanation.
So I ordered and OEM cover from Mini Parts Direct. Long story short do not buy aftermarket.
Old Oct 7, 2021 | 04:13 AM
Yusssi's Avatar
Yusssi
Web link?
So I ordered and OEM cover from Mini Parts Online. Long story short do not buy aftermarket.
Hi, what is the link to that website? I have found a few results and not sure which one to "trust".
TY!
Old Oct 7, 2021 | 07:37 AM
TY!
I ordered the OEM valve cover from https://www.minipartsdirect.com/
I installed it last weekend, so far no leaks or oil blowby.
Old Oct 7, 2021 | 08:04 AM
CountryJim's Avatar
CountryJim
For what it's worth, ECS tuning has an OEM cover+gasket+hardware as well, with 2 year warranty. I installed mine and everything works perfectly.
ECS tuning - R60 Valve Cover
Old Oct 7, 2021 | 08:54 AM
y8s's Avatar
y8s
I just installed the Mostplus branded one from Amazon. It's $76 USD and fit like OEM.
Old Oct 7, 2021 | 08:58 AM
It was the Amazon one that caused all of my issues. So I recommend to Stay Away. On the bright side, Amazon did take it back. But did not refund the countless hours I spent cleaning up oil.
Old Oct 7, 2021 | 09:07 AM
Yusssi's Avatar
Yusssi
right on, ty!
Old Oct 7, 2021 | 09:31 AM
Yep, we have these options:
https://www.ecstuning.com/Search/Sit...h/11127646552/
Old Oct 11, 2021 | 06:37 AM
y8s's Avatar
y8s
"the" amazon one... There are dozens on there. can you be a bit more specific?
For example I got this "the amazon one": https://smile.amazon.com/gp/product/B091BT6DR2
And it installed like butter and just got home from a weekend road trip without issues.
So unless you're going to pay the $350+ for the Genuine MINI one, then any other brand from Amazon or anywhere else (no disrespect to ECS--I go there first for my parts), then why not save yourself some coin?
Old Oct 11, 2021 | 07:34 AM
I got the same one and that was the one that caused the issues, The fit and quality were not the same as the factory. I also believe all the other versions on amazon come from the same Chinese manufacture by looking at the markings.
Old Oct 11, 2021 | 07:50 AM
y8s's Avatar
y8s
Interesting.
Also I noticed your tightening order was different than in the factory service manual (same: torque to 10 nm / 7.5 ft-lbs / 88.5 inch-lbs):
(yes the image below is weird, but that's what in "11 12 000 Removing and installing/sealing cylinder head cover (N18)")
edit: oh it's not weird, just missing the PCV cover...
No idea how sensitive the valve cover is to tightening order but I just thought I'd throw it out there.
Old Oct 11, 2021 | 10:45 AM
Interesting.
Great information here I have looked all over for a manual where did you get yours?
Old Oct 13, 2021 | 07:10 AM
y8s's Avatar
y8s
Technically the manual is not available.
It used to be freely available here: https://www.newtis.info/
But sadly now it is not. I'm not sure if you can still sign up, but it can't hurt to use the feedback link.
Beyond that, you can go through the incredibly complicated process of finding a complete windows virtual machine preloaded with every bmw software out there (it exists...) and spin it up on your own host, but ... yuck.
Frixos
Dec 30, 2019 11:24 AM
Price
May 20, 2018 05:04 PM
NeonLed
Nov 20, 2015 07:49 PM
JTmini08
Mar 8, 2014 03:20 PM
madmaxxed
May 22, 2011 06:33 AM
