R60 Cooling fan won’t start
Old Oct 1, 2019 | 02:22 PM
Alexr54's Avatar
Alexr54
Hey all!
So first off I got a dreaded CEL and noticed the AC was not cooling good when the car is stopped. As soon as I start moving the AC works great.
The code I got was P0597.
so I changed the thermostat housing to a new OEM thermostat housing with temp sensor.
I cleared the code and it has not come back, but the AC still is not working while stopped.
I also feel the car kind of hesitate or stutter at times when stopped. I think when the AC compressor kicks on. The cooling fan still does not work at this point.
So I kept checking and then noticed my fan is not spinning at all. I tried jumping the fan and it would not start. So I replaced the cooling fan.
I am having the same issue. The new fan won’t start as well. Engine is reaching 220°F and no fan.
I checked all fuses and they are all good.
One strange thing is I have only 3 relays, the 4th relay slot for fan is empty.
any ideas on what I should check next?
its a 2012 r60 base.
Old Oct 2, 2019 | 11:30 AM
Alexr54's Avatar
Alexr54
Fixed my problem.
the old fan was bad. The new fan was good but the plug was bad.
fixed the plug in the new fan and all works as it should now.
Old Oct 2, 2019 | 06:30 PM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
Thanks for checking in with the fix. If more people would do that it would be awesome!
Old Oct 3, 2019 | 08:27 AM
Alexr54's Avatar
Alexr54
I agree. Hopefully this will help someone in the future with a similar issue.
not too much info out there for r60 mechanical work.
Swingerstunt
May 23, 2017 12:21 PM
buckeye_hunter
Oct 24, 2013 07:00 AM
Sisith
May 22, 2010 04:58 PM
gokaht
Apr 24, 2008 09:04 AM
