R60 WOW Great Place - My Old Mom need help please
Old Jul 7, 2015 | 01:11 PM
BennyF's Avatar
BennyF
Found this form for some great info on the Mini
My mother always wanted a mini and we all got her one. She is disabled but can still drive.
Well, on to my story. She got a Mini Countryman base with cold weather and premium. The dealer failed to tell her there were no fogs OR NO DRL'S.
Being in law enforcement myself, I really feel DRL's are a great safety feature. The dealer now says no way to get DRL's and it does not show up in the BC settings as well. Mini's website says there standard now, but she got a build before some changes. My dad called Mini, and got the "what can we do about it, see the dealer". and the dealer plays dumb...
Anyway to get this to work, coding...anything please, my mom really wants them, heck, you know older people are. Thanks all
Old Jul 7, 2015 | 01:45 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Believe the MINI LED daytime running lights should work for the R60 Countryman. Part # 63122338554. According to RealOEM this kit should fit your Countryman.
888.280.7799 | 6am - 5pm PST
Old Jul 7, 2015 | 02:51 PM
BennyF's Avatar
BennyF
We were told you need the factory fogs for this kit. Which it does not have. There is no switch in the center console for fogs too. hey thanks!
Old Jul 7, 2015 | 03:52 PM
PelicanParts.com
Vendor
ah I see. Maybe find a local audio or fabrication shop that may be able to hook these lights up for you. My non-MINI car had fogs, but I went with a different set up and had them wired directly to the battery so I could use them while the car is off, which I had to re-wire a bunch of stuff. I'm sure this is something that can be easily done by a shop like that or a MINI indy shop. May be worth asking around. Good luck.
Old Jul 8, 2015 | 05:09 AM
For the DRL fogs you will need the factory fog lights: 63122338554
https://www.northamericanmotoring.co...-w-o-fogs.html
The option for people without factory fogs is the Ziza Postion light leds. Its in the link above.
Thanks and hope that helps.
Old Jul 8, 2015 | 05:22 PM
BennyF's Avatar
BennyF
thanks, do the parking lights turn off when the ignition is off?
Old Jul 9, 2015 | 05:15 AM
They stay on when you click them up one notch on the stock. Which you can do when you enter the MINI each time. Unless you code them through a secondary NCS expert like software program like a drl. Which some people do.
Old Jul 9, 2015 | 06:14 AM
BennyF's Avatar
BennyF
Thanks, any coders in Ohio or Michigan Please
Old Jul 9, 2015 | 06:31 AM
Helix13mini's Avatar
Helix13mini
You can also code DRLs from your high beams at half power without installing the driving light kit. You'll need to find somebody who is advanced at coding. Ohio is a bit far from Philly, but if you want an epic road trip for some lights, come to Helix.
Old Jul 9, 2015 | 06:32 AM
Welcome.
I don't know anyone local, the NCS expert is for individuals to code electrical things :
https://www.northamericanmotoring.co...beginners.html
Old Jul 9, 2015 | 08:43 AM
DWooderson's Avatar
DWooderson
What about just leaving the headlights on 100% of the time? K.I.S.
Also, if you update codes, isn't it likely that Mini will wipe out the customization next time they service the car?
Old Jul 9, 2015 | 08:58 AM
BennyF's Avatar
BennyF
Hey, your the man...this is exactly what we need!!!!!! I would pay you to help me with buying the rights stuff and software to do it
Does the software come in Mac Apple OS.
thanks
anyone code in MI or OH please contact me.
Old Jul 9, 2015 | 09:00 AM
BennyF's Avatar
BennyF
She does that now, but that leaves ALL the lights on, tails, dash, etc. all and just a waste of bulbs. But she is doing that for now.
Old Jul 9, 2015 | 09:43 AM
DWooderson's Avatar
DWooderson
Bulbs cost nearly nothing compared to all the retrofitting, but I realize and respect that this may be more of a "do it the right way" mission.
Good luck with the project!
Old Jul 10, 2015 | 05:20 AM
BennyF's Avatar
BennyF
I saw some rally lights on ESCtuning.com. Anyone make these into drls. Someone said they only work with the hi-beams.
Anyone make them come on and off with the ignition only like drls. If so, these are the ticket.
Old Aug 1, 2015 | 06:06 AM
Csbdr's Avatar
Csbdr
There are regulations governing installation and use of accessory driving lights like rally lights. Being in law enforcement you probably already know having them always on when the car is on will get your mom pulled over and a ticket.
Old Aug 1, 2015 | 02:47 PM
BennyF's Avatar
BennyF
yes, we have been looking into it, thank you
Old Aug 1, 2015 | 07:59 PM
S4SF's Avatar
S4SF
Whammy! Do you know how many bulbs you can buy for the price of one retrofit kit? And how many more bulbs can you buy for the price of installation? Then what if it isn't installed correctly and either fries a module or drains the battery, leaving your mom stranded? Having tail lamps on can also make the vehicle more visible from the rear, and less prone to being rear ended. (okay, that's a little far fetched)
But.......sounds like using the headlights is quite reasonable
Old Aug 2, 2015 | 06:36 AM
BennyF's Avatar
BennyF
agree that is what we are doing... thanks for your reply
Old Aug 2, 2015 | 07:03 AM
Eddie07S's Avatar
Eddie07S
Do an search on NAN for the thread BMWhat app. This is a cell phone app that works with a wi-fi OBDII port reader to change a lot of the settings that dealers can set. If it is available to be "set" in a MINI this should do it for you. It works much like the NCS expert only easier.
blackie
Jan 18, 2017 09:56 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
serrow
Hawaii
Aug 19, 2015 11:35 AM
maniacalmorgan
Aug 19, 2015 08:44 AM
Aug 11, 2015 09:01 AM
