R60 Is the 2014 Countryman S prone to carbon buildup?
Old May 28, 2014 | 04:46 PM
boognish's Avatar
boognish
I've been reading many threads here about extreme carbon buildup that has plagued certain Mini Cooper S engines. Which model years are most prone to this, and was the buildup due to a design issue that has since been rectified?
Old May 28, 2014 | 04:59 PM
danjreed's Avatar
danjreed
Pre 2010 (n14) engine models had the carbon issue. I believe most if not all countrymen had the n18 except for a very few early models.
Old Jun 2, 2014 | 08:34 PM
CN R60's Avatar
CN R60
The CM has only been available with the n16/n18.
As for the carbon issue, I don't know specifically about the n18 however I believe that all direct-injected engines are prone to carbon build-up to some degree, except for certain designs which also have an injector in the intake. Do a search for "bmw walnut shell cleaning".
Old Jun 24, 2014 | 10:33 AM
The X Men's Avatar
The X Men
BMW and Audi's carbon build up problem have been fixed for the most part on the newer models with the exception of a few high performance engines. Does anyone have a 2010 or newer mini that has carbon build up issues?
Old Jun 24, 2014 | 11:25 AM
yetti96's Avatar
yetti96
It's direct inject, it will happen eventually. Many other brands are going this route too. In a few years this will be common maintenance.
Old Jun 24, 2014 | 02:08 PM
The X Men's Avatar
The X Men
There are very few carbon build up issue in the 2012+ BMW and Audi DI engines. I think they have it figured out.
Old Jun 28, 2014 | 04:03 PM
shark715's Avatar
shark715
If that were true, wouldn't we be hearing about it by now? There's numerous early Countryman owners out there that are now over 75K miles, and I can't recall anyone here reporting the issue. If you look a the 2nd generation section of the website, you will see numerous owners reporting the problem at far less mileage. Or are you saying the problem is inevitable with DI engines, but with the changes it will just happen at much higher mileage?
Old Aug 21, 2017 | 10:01 PM
osnapcoopertime's Avatar
osnapcoopertime
Its a few years later and Im looking for this answer to after someone scared me about DI engines and this issue with the GTIs
Waszak
Oct 21, 2017 05:55 PM
PParker74
R55 :: Clubman Talk (2008+)
Aug 30, 2015 04:20 PM
Pacman2131
Aug 27, 2015 09:25 AM
SunnySideUp
R57 :: Cabrio Talk (2009+)
Aug 26, 2015 01:16 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
