R60 Sport Suspension
Old Mar 15, 2014 | 09:29 PM
rdd337's Avatar
rdd337
Sport Suspension or Not?
HI,
I just ordered my Countryman S with JCW exterior package and the salesman added the sports suspension by mistake. Its free upgrade for JCW exterior package if you want to. I just saw it when I got home. Should I upgrade to sports suspension or not? I'm just afraid if the ride will be harsh with sports suspension specially the package also comes with 18" wheels. I live in bay area and most roads are decent. No potholes. Should I change it or keep the sport suspension in my order? Thanks.
Old Mar 16, 2014 | 11:45 AM
bmwr606's Avatar
bmwr606
i have an all4 with sport suspension and sport pkg (18 inch wheels) and my sister has an all4 with standard suspension
i much prefer my car over the standard suspension, much less body roll, much better handling
Old Mar 16, 2014 | 07:55 PM
hsautocrosser's Avatar
hsautocrosser
Would you prefer it if you still had the runflats?
Old Mar 16, 2014 | 08:01 PM
bmwr606's Avatar
bmwr606
yes, would not have a mini without sport suspension
Old Mar 16, 2014 | 08:45 PM
Roxspin72's Avatar
Roxspin72
I just ordered the Same...
Get it!!! Ordered the same set up for my wife and I'm Sure she will be happy!!!
Old Mar 16, 2014 | 09:07 PM
rdd337's Avatar
rdd337
thanks to all reply. apparently even though my home pc shows i have option not to get sport suspension with jcw exterior package, when the dealer ordered my cm theres no other choice but to get the sport suspension with jcw ext package or cancel the package. hopefully the ride wont be that harsh when my cm gets here.
Old Mar 16, 2014 | 09:14 PM
bmwr606's Avatar
bmwr606
The 18 inch runflats rode terrible until I upped the tire pressure from the stock 32 psi to 38 psi ... 38 psi is listed in the OM as an alternate pressure for high speeds ... made a huge improvement ... I ended up using 37 psi rear and 42 psi front
Old Mar 17, 2014 | 05:52 AM
jaxdw57's Avatar
jaxdw57
Sport vs Standard
OK, I have an 06 MCS with the sport package. I would like to soften up the ride some, I have gone to regular tires no run-flats. This has helped to some degree but here's my question. Can I change out springs, shocks, ect to turn it into a non-sport suspension? If so, what all would I have to replace. I don't track the car and am a little older so I'm just trying to soften up the ride so it won't beat these old bones up! LOL! Thanks for any help and or advise.
Old Mar 17, 2014 | 06:44 AM
chrunck's Avatar
chrunck
You could install Koni FSDs. I found them to ride a lot better than the OEM struts, but still held together well in the turns.
Old Mar 17, 2014 | 08:30 PM
rdd337's Avatar
rdd337
sport suspension upgrade vs jcw
Do they use same suspensions between the suspension upgrade and the one they use for JCW countryman? If not, which one is stiffer? Thanks.
Old Mar 17, 2014 | 08:42 PM
bmwr606's Avatar
bmwr606
i have read that they are the same, but you could check realoem.com to know for sure
Old Mar 18, 2014 | 09:09 PM
rdd337's Avatar
rdd337
thanks. cant wait to pick up my cm.
Old Sep 2, 2014 | 07:16 PM
sdwaterbaby's Avatar
sdwaterbaby
Hi all, I have a 2014 JCW Countryman AWD and though it does come standard with the "Sports Suspension" package there is an optional "Sports Tuned Suspension" package that comes with beefier front and rear sway bars and stiffer springs...I didn't realize that and only have the standard sports suspension package. Question: Does anyone know if there is a better rear sway bar and adjustable rear lower control arm package out there that doesn't totally screw with the suspension geometry (and that Mini won't say will void the warranty)? The back-end of my car really dances around at times and it has taken the thrill out of hard-cornering and bumpy roads! And, has anyone gone through a Mini dealer to have these kinds of upgraded suspension components installed and if so, how did it go and was it big $$$? Thanks!!!
ej
Nov 17, 2015 09:21 PM
molala
Oct 2, 2015 01:53 PM
RDSJCW
Sep 16, 2015 03:54 PM
atlantaorange
Sep 16, 2015 12:43 PM
Suspension Products
Sep 10, 2015 11:46 AM
