R60 Rotten Egg Smell from Exhaust
Old Jan 15, 2014 | 06:28 AM
pidge1114's Avatar
pidge1114
I have a rotten egg odor coming from my exhaust. It is usually after driving a little while, and more noticeable after hard driving. From what I understand, this could be one of 2 things: 1) bad gas with high sulphur content, or 2) a failing catalytic converter.
My car is the S All 4 with 11,000 miles on it.
Anyone have similar issues? If it is the cat, is that caused by my engine running too rich with excess fuel being burned in the cat?
Old Jan 15, 2014 | 07:41 AM
Helix13mini's Avatar
Helix13mini
It's more likely option 2, although a cat can be stinky under hard driving without failing. If you notice that it stinks under normal driving, that's trouble.
Old Jan 15, 2014 | 08:05 AM
yetti96's Avatar
yetti96
Under warranty is one thing or the simple solution, go catless Noise and smell.
Old Jan 15, 2014 | 08:41 AM
Dustypants's Avatar
Dustypants
pidge, i have the same thing going on, but only under hard driving. I thought it was maybe the JB, but after having a loaner car with no JB and smelling the same thing out of a brand new car with less than 10K on it, i figured it to be normal.
Usually only notice it when the window is down and i'm really really "on it".
Old Jan 15, 2014 | 08:59 AM
pidge1114's Avatar
pidge1114
Yes I notice it most when I drive aggressively. Don't know if the JB affects the AF ratio whereas it makes the car run rich to account for the smell.
I'll have to keep my nostrils open to see if it keeps up and in normal driving. At least I have CEL and I ran Dash Command and I get no codes.
Old Jan 15, 2014 | 10:50 AM
VanessaVELEZ's Avatar
VanessaVELEZ
What grade of fuel do you use on the car? I go 93 Octane always.
Old Jan 15, 2014 | 11:37 AM
pidge1114's Avatar
pidge1114
I use BP 93 Octane and have since day 1.
Old Jan 15, 2014 | 06:29 PM
watchluvr4ever's Avatar
watchluvr4ever
Sulfur in gas perhaps?
Old Jan 15, 2014 | 08:11 PM
mikey_t's Avatar
mikey_t
You might want to read this article on sulfur smells from the CAT: Seems that things like a defective fuel injector, oxygen sensor or pressure regulator will allow excessive unburned fuel to enter the cat and result in the sulfur smell. Sounds like that's something that would be made worse by hard driving.
Old Jun 28, 2014 | 08:58 PM
adrianaq17's Avatar
adrianaq17
My 2012 S has had the smell when I drive hard from day one. I also do notice that my car will "stumble" at times when accelorating. After reading the article about CAT I'm kind of nervous. I just got my oil changed today with no reported issues other than one tire that has worn weird and needs to be replaced (that's a whole different Oprah). Did anybody have luck with getting this issue resolved?
Old Jun 29, 2014 | 07:57 AM
Lonewolf's Avatar
Lonewolf
BP Fuel that could be the problem JMO
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
embiggenedmini
Oct 15, 2015 12:36 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
