R60 Spring/ Shock Absorber difference between sport and standard suspension?
Old Sep 5, 2013 | 07:49 AM
preme123's Avatar
preme123
What are differences between sport and standard suspension? Do they carry a different part number for the springs and shock absorbers?
Also, If I remembered correctly, I heard that the Paceman handles differently from the countryman?
and the center of gravity is about one inch lower?
How is that possible? Why does it drive different? Is the paceman's standard suspension setup same as the sports one in the ctm?
Old Sep 5, 2013 | 06:58 PM
DR61's Avatar
DR61
The springs, dampers, and sway bars are different with the SS option. The Paceman has the SS option as standard (same as optional SS on CM), and normal CM suspension optional. The SS cars sit 10 mm lower (.4"). Sway bar is 1 mm larger on rear for SS. In front sway bar is 2 mm larger for SS. Shock(damper) valving is different.
Old Sep 5, 2013 | 07:45 PM
14PacemanS's Avatar
14PacemanS
That is incorrect...the Paceman has the Standard Suspension...UNLESS you specified the Sport Option. I know MINI and several mags stated otherwise, but that is not the case. Anytime I built one online the default was the standard suspension.
I am told the Sport is 10mm lower than the standard, not sure about the struts/shocks.
Old Sep 6, 2013 | 04:19 PM
DR61's Avatar
DR61
I stand corrected about SS being the default suspension; apparently Mini changed this before actual deliveries.
theblackfalcon
Oct 11, 2015 09:49 AM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
