R60 50 or 55 series
Old Mar 8, 2013 | 10:31 PM
busyguy8's Avatar
busyguy8
50 or 55 series
Hey gang, I'm finally ditching the run craps. I've got the stock 18's with the 225-45's.. I want to go as tall as I can without lifting. I was gonna lift the car, but decided against it. Will 225-55's rub at stock height? I know the 225-50 will clear.
TIA,
-bg8
Old Mar 8, 2013 | 11:43 PM
bmwr606's Avatar
bmwr606
i am running 205/70R16 winter tires, od is 27.3" and there is no rubbing, but it is very close at full lock and when the suspension is compressed
a 225/55R18 is both wider and taller at 27.8" od ... i suspect it will rub
i would suggest a test fit of the 225/55R18
i test fit the 205/70s at a neighborhoos independant tire store ... we also test mounted a 205/75R16 of 28.1"OD and it rubbed
please post your results
scott
Old Mar 9, 2013 | 08:51 PM
doug_all4's Avatar
doug_all4
215/60r17 fit fine and makes the speedometer exactly match gps.
Old Mar 9, 2013 | 08:56 PM
busyguy8's Avatar
busyguy8
we test fitted the 225-50-18's and I liked the look enough, and given it's my daily driver, I decided that would good enough. then I took it for a drive.. WOW!!! All I can say is ding dong the witch is dead.. good bye RUNCRAPS!
Old Mar 10, 2013 | 12:27 AM
bmwr606's Avatar
bmwr606
when my oem 225/45R18 pirelli p7s wear out i will be installing michelin 225/50R18 pilot super sports
scott
OutMotoring
Nov 16, 2015 07:04 AM
nashvillemini
Sep 30, 2015 10:26 PM
E-dot
Sep 28, 2015 03:01 PM
stoneunhenged
R58 :: Coupé Talk (2012+)
Sep 24, 2015 02:19 PM
mini pooper
RSR Motorsports Coverage
Sep 24, 2015 10:19 AM
