R60 What is This?
Old Sep 1, 2012 | 06:22 AM
shark715's Avatar
shark715
What is This?
What is this "nub" sticking out of the floor by the left end of our rear bench seat? There's a similar one by the right end of the seat too. I thought it might be a some sort of a cargo tie down, but I don't see any mention of it in the owners manual.
Old Sep 1, 2012 | 07:41 AM
ghamma's Avatar
ghamma
If you take off the plastic cover you'll find eyes that can be used for tie-downs. I got a ratchet strap at Harbor Freight and run it from tie-down to tie-down over the laid-down back seats, running it over the headrest supports to pull
the seats down to a flatter position for hauling stuff. I throw a moving blanket over the back and it works great for quickie cargo conversion.
Old Sep 1, 2012 | 07:48 AM
shark715's Avatar
shark715
Thanks! That's what I thought they are, but the covers are what confused me because they don't readily come off. I tried pulling them off again just now, and they are not coming off. I'm concerned that I'm going to break the covers. Do I need to twist them as I pull?
Old Sep 1, 2012 | 08:36 AM
Koopah's Avatar
Koopah
While moving a futon sofa, I also found that if your tie-down strap goes over a heavy object positioned on top of the folded down seat backs, you can go diagonally from the pictured tie-down points to the tie-downs near the corners of the tailgate opening. The load is very secure and does not shift. In the case of the futon mattress, it also nicely compressed it so I could easily see out the rear window!
Old Sep 1, 2012 | 09:02 AM
shark715's Avatar
shark715
Thanks Koopah, any trick to getting the covers off?
Old Sep 1, 2012 | 09:12 AM
Jim Michaels's Avatar
Jim Michaels
You might try prying it up with a screwdriver tip; working under the bottom lip a little at a time.
Old Sep 1, 2012 | 09:18 AM
shark715's Avatar
shark715
Thanks, as silly as it sounds, I'm still struggling with both of them. Is the part that goes flat against the carpet part of the cover, or not? One would think the cover would pull off in with little trouble.
Old Sep 1, 2012 | 09:28 AM
Jim Michaels
From your photo, the flat part at the bottom of the plastic cover that rests against the carpet appears to be part of the cover.
I assume there was no "rear tie-down delete kit" option available for the Countryman.
Old Sep 1, 2012 | 09:45 AM
shark715's Avatar
shark715
Problem solved! I was assuming the flat part was the tie down itself versus the cover. Thanks everyone and have a great weekend!
Old Sep 4, 2012 | 03:11 PM
Jeff Dorchester's Avatar
Jeff Dorchester
In my case, it's also for the factory cargo net option. I guess I could also call this the anti-child throw option.
Old Sep 4, 2012 | 10:10 PM
countryman-s's Avatar
countryman-s
FACTORY CARGO NET OPTION! Never heard or seen this before. How did you find out about this? Is there a secret countryman option catalog I'm missing? I have seen a cargo net for the back, but never seen one for behind the front seats. This could keep my crazy dog in the back. I think he wants to drive
Old Sep 5, 2012 | 08:48 AM
Jeff Dorchester
My dealer had never heard of this before either. He found the part in the trunk and said, "What's this?" So he checked and sure enough it was the "cargo net" listed on the window sticker.
Here are some good pics of someone else's net https://www.northamericanmotoring.co...-net-pics.html.
Old Sep 5, 2012 | 10:23 AM
ghamma's Avatar
ghamma
I like the idea of this barrier - but the option apparently includes the circular attachment points forward of the rear handholds above the door - not present on my CM4!
Old Sep 5, 2012 | 10:33 AM
aleclee's Avatar
aleclee
I noticed it in the configurator but the picture made it look more like a boot tie-down than something to keep stuff from sliding forward with the seats down. Either way, it wasn't something that would make me part with the $250 they want for it.
