R60 Why do our engines sound the way they do?
Old Mar 24, 2014 | 01:01 AM
  #26
Melangell's Avatar
Melangell
Old Mar 24, 2014 | 05:12 AM
  #27
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
For the sake of....updating this engine idle sound decibel concern, I'll add my 2 cents.
BMW engines are direct injection and yet do not sound this way....that said, injector part no. 13537591623, have been superseded. With that supersession was a new injector ring kit that doesn't fit the old injectors and is supposed to quiet that racket down some.
Old Mar 24, 2014 | 07:16 AM
  #28
DneprDave's Avatar
DneprDave
Still good to know. Thank you, Sportysally.
Dave
Old Mar 24, 2014 | 02:46 PM
  #29
sportysally's Avatar
sportysally
Originally Posted by -=gRay rAvEn=-
For the sake of....updating this engine idle sound decibel concern, I'll add my 2 cents. BMW engines are direct injection and yet do not sound this way....that said, injector part no. 13537591623, have been superseded. With that supersession was a new injector ring kit that doesn't fit the old injectors and is supposed to quiet that racket down some.
Interesting info. Thanks!
Old Mar 24, 2014 | 11:26 PM
  #30
CN R60's Avatar
CN R60
Thanks for the info. I wonder when they started using the new injectors? FWIW my 10/13 build R60 makes a lot of ticking noises at idle.
Old Mar 25, 2014 | 12:58 AM
  #31
CN R60's Avatar
CN R60
By the way, I should mentioned that I'm not so much bothered by the ticking but rather the gruff sounding exhaust. Though part of this may be due to the single exhaust of my Cooper ALL4 (it doesn't have the dual exhaust of the S).
Old Mar 25, 2014 | 02:00 AM
  #32
52804x4's Avatar
52804x4
Huh? How do you have an All4 that is NOT an "S"?
Old Mar 25, 2014 | 07:47 AM
  #33
ASKtheteach's Avatar
ASKtheteach
I read a while back that they were going to be making non-S All4 models. Not sure if they are/will be available in the US.
Old Mar 25, 2014 | 08:07 PM
  #34
MsBrit's Avatar
MsBrit
Here is the response I got from my SA when I asked about the start up engine noise: "Noise is caused by the turbocharger westgate. Per sim 18 01 10 the noise is caused by the turbocharger westgate. The westgate stays fully open during cold start to insure proper valve seating to meet stricter ulev2 emissions criteria. This noise is normal and necessary".
Old Mar 26, 2014 | 01:31 AM
  #35
CN R60's Avatar
CN R60
The Cooper ALL4 was offered in certain markets starting from the second half of last year. What is interesting is that the automatic version uses the same turbo engine as the S. See http://www.totalmini.com/forum/39-mi...yes-turbo.html
Old Mar 26, 2014 | 01:33 AM
  #36
CN R60's Avatar
CN R60
That is correct, and so far it is not available in North America and I would guess it won't ever be.
Old Apr 20, 2014 | 10:09 PM
  #37
CN R60's Avatar
CN R60
Some more info - the production code for this particular model (Cooper ALL4 automatic with turbo) is XD71.
And to bring this thread back on topic, there was a Countryman One idling outside my office this morning and I tried to get a good listen at its noises (without bringing myself to the attention of the owner). While it also had some ticking the noises were noticeably less than mine. Doesn't the non-turbo (N16) also have DI? However, does it have valvetronic? If not, could that explain the differences in the ticking noises between the N16 and N18? Has anyone else here compared the two?
By the way, this would be a pre-2013 model from the lack of lettering on the back (not that I think this makes a difference).
woodstudio
Mar 15, 2020 08:28 AM
David.R53
Sep 1, 2015 06:49 PM
makg
Aug 21, 2015 02:49 AM
damncajun
Aug 17, 2015 08:25 PM
