R60 Donut Tire/Wheel for Countryman
Old Jan 28, 2011 | 10:02 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Donut Spare for Countryman ?
Content and photos deleted by me.
You have Robb M. from Internet Boards to thank for that....
Old Jan 30, 2011 | 04:10 PM
minibickle's Avatar
minibickle
The BMW X3 spare donut in size 135/90/R17 fit just perfectly. No rubbing or clearance issues even in the front, and is an almost an exact match in circumference to the OEM wheel rim/tire set up for the 17's.
Old Jan 30, 2011 | 06:15 PM
-=gRaY rAvEn=-
Moderator
It'
Old Jan 31, 2011 | 03:25 PM
Miniblue2's Avatar
Miniblue2
The diameter is still way too much to fit in the bootwell. I measured and it is a bit over 17". Because of the brakes the wheel needs to be 17" minimum, so I've heard. I think if I decide to go runflatless I will get a setup of 5 tyres and buy one more rim from Mini. It will be that much less when time for tyres again.
Old Jan 31, 2011 | 05:15 PM
snowboard1's Avatar
snowboard1
Sounds good , Did you try it on the car? was it an S?
Old Feb 5, 2011 | 06:45 AM
-=gRaY rAvEn=-
Moderator
111
Old Feb 17, 2011 | 05:59 AM
snowboard1's Avatar
snowboard1
I want to get one of these when I switch to non RFs!
Quick question - I am not exactly sure how the ALL4 system works- would the small difference in diameter cause any issues, not sure if the there are sensors monitoring rotation/slip
Mike
Old Feb 21, 2011 | 10:06 AM
Mini Mania Info's Avatar
Mini Mania Info
Mike
Since the spare donut does not have the TPMS sensor - your flat indicator will be lit.
As for the ALL4, there should be no issues as long as the donut is used to get you to the nearest tire repair facility. The ALL4 is in FWD mode until you lose traction in the front - only then does the rears kick in.
Cheers,
Ken
ps: The compact spare tire for the COUNTRYMAN is available on our site here.
Old Mar 19, 2011 | 09:44 PM
bradrulz's Avatar
bradrulz
Once I get my Countryman and the OEM run flats wear out I would like to replace with standard non-run flat tires. Was wondering what size donut all of you are using that have already replaced or where a good place to buy donut wheel and tire is? I will have the 18 inch 245/45/18 tires as I am getting the sport package.
Old Mar 19, 2011 | 09:56 PM
lindseybp's Avatar
lindseybp
I replaced my 18" run flats with non run flats before we took delivery. Not using a spare. Getting some tire slime.
Old Mar 19, 2011 | 10:00 PM
bradrulz's Avatar
bradrulz
Did the dealer do an even swap out or did you have to pay out of pocket for the replacements?
JudgeS's Avatar
JudgeS
I only use Slime if nothing else works, get a tire plug kit, it's really easy to plug a leak.
Old Mar 20, 2011 | 05:31 AM
-=gRaY rAvEn=-
Moderator
Originally Posted by bradrulz
once i get my countryman and the oem run flats wear out i would like to replace with standard non-run flat tires. Was wondering what size donut all of you are using that have already replaced or where a good place to buy donut wheel and tire is? I will have the 18 inch 245/45/18 tires as i am getting the sport package.
w
Old Mar 20, 2011 | 09:20 AM
lindseybp's Avatar
lindseybp
No. Bought the tires on my own. Took the run flats home and going to sell them.
notrickross
Southern California
57
Aug 23, 2018 07:05 AM
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
Sep 14, 2015 12:48 PM
Norton70
Sep 7, 2015 05:06 PM
dandw2
Sep 7, 2015 11:14 AM
