R60 Some new mods on the CMS
Old Jun 1, 2011 | 07:52 PM
  #26
docfink's Avatar
docfink
No movement here...maybe undo it, spray windex and reinstall...
Originally Posted by Flyer53
docfink…Does your JCW shifter move or is it locked in ? I don't mean up & down…but sort of spins a little left & right. It seems to drop in nice and locks…but there is some movement back and fourth.
...if that doesn't do it, take it to the shop.
Old Jun 2, 2011 | 06:20 PM
  #27
Flyer53's Avatar
Flyer53
docfink..Gave it a good smack and it locked right in. Thanks again
Old Jun 4, 2011 | 04:19 AM
  #28
Flyer53's Avatar
Flyer53
Posted some pictures in my gallery on some of the completed modifications
Piano black>>to carbon fiber, also upper swtch bank. Finishing center console
should be ready next week.
Old Jun 4, 2011 | 05:21 AM
  #29
Rktcyntst's Avatar
Rktcyntst
That looks sick! I can't wait to see the final install!
Are you doing all the work yourself? Is that a carbon fiber skin, paint or something else? Nice work!
Old Jun 4, 2011 | 09:35 AM
  #30
Flyer53's Avatar
Flyer53
Thanks, it's part of what we do here…abrasive blast..also known as sand blasting…but we use steel grit, aluminum oxide, glass bead or crushed glass to clean and strip the existing coatings back to bare metals, all dependent on the material, painting, powder coating, and heat treating. Mostly aerospace, mfg., industrial, commercial..but we enjoy the fun stuff as well, wheels, car, truck & bike frames.
The carbon fiber is part of a process called Hydrographics…a lot of prep work…masking, prime epoxy, sand, urethane, sand & float the pattern and then a dip in the tank with the piece. Everything we do…it's all about the correct prep. whether paint, powder etc.
Old Jun 8, 2011 | 07:45 AM
  #31
Flyer53's Avatar
Flyer53
Finally had time to finish up on the center console..still needs clear.
Should have that back in and the 2nd armrest for the back seat passengers installed as well….Now…should I even start to think about the cradle.
pictures in the gallery.
Old Jun 12, 2011 | 10:01 AM
  #32
Tacoman03's Avatar
Tacoman03
How did you remove the "Cooper" placard on the trunk lid?
Old Jun 12, 2011 | 02:00 PM
  #33
mavic1010's Avatar
mavic1010
I had it removed when I got it detailed. However, its easy to remove. Get some tooth floss, hair dryer and some adhesive remover. Heat it up to lossen the adhesive then use tooth floss to remove it. The use adhesive remover to get off all the left over gunk. Then use polish and sealant.
Old Jun 12, 2011 | 10:18 PM
  #34
John Richard's Avatar
John Richard
Was the tone of the exhaust changed any after the tips were installed?
Old Jun 27, 2011 | 07:29 PM
  #35
napolean2424's Avatar
napolean2424
Tips
I think the new tips will be my first upgrade. In fact I'd like to get them before the car comes in, it's an "S" if that matters, but are these the right inlet size to go with the 4" outlet:
http://www.magnaflow.com/02product/s...e=main&id=9407
Old Jun 28, 2011 | 05:55 PM
  #36
inimini2007's Avatar
inimini2007
Same ones I got...they have to modify it slightly...
When they jack your car up...look how big the muffler is.
Old Jun 28, 2011 | 05:59 PM
  #37
inimini2007
Summit Racing has them for under $35 ea and should be free shipping.
Magnaflow tips should also have a lifetime warranty.
Old Jun 28, 2011 | 06:28 PM
  #38
napolean2424
Tips
Thanks for the info, and I look forward to getting this mod done. Mininnovative!
Old Jun 30, 2011 | 07:55 AM
  #39
ALL4TURBO's Avatar
ALL4TURBO
At first I didnt notice much, but its been a week now and I found the sport button.. There is a noticable difference in sound. Its not loud by any means, but its has a little more sound. The pop and burble is awesome.. Even as hot as its been here I've had the windows down all week..
I added these tips. Black Powder coat looks so sweet..
http://www.assuredautomotiveproducts...AC013b-BKG.htm
Old Aug 1, 2011 | 07:17 PM
  #40
mini_z's Avatar
mini_z
Originally Posted by mavic1010
Latest mod.....
I see an Auto, did u loose the paddle shifters?
Old Aug 2, 2011 | 02:42 PM
  #41
sirbikes's Avatar
sirbikes
Here's a mod I'd like to see - change the clutch engagement point to be closer to the floor.
Old Aug 3, 2011 | 08:31 AM
  #42
mavic1010's Avatar
mavic1010
Yes. Didn't use the paddle shifters and you can't have a JCW with paddle shifters unless you modify it. You do need a different harness though.
Old Dec 25, 2011 | 04:12 AM
  #43
evobunny's Avatar
evobunny
can anyone describe the differences from stock steer wheel with the jcw. Like with the looks and feel.
Old Dec 25, 2011 | 04:21 AM
  #44
docfink's Avatar
docfink
The JCW is thicker and has alcantara. It's a nice upgrade and I'm happy with it. It's a nice complement to the JCW shift ****.
Old Dec 25, 2011 | 07:38 AM
  #45
mavic1010's Avatar
mavic1010
The JCW Steering wheel is either all leather (which I have) or leather/alcantara. Its thicker and is a nice upgrade over stock.
Old Dec 25, 2011 | 04:07 PM
  #46
evobunny's Avatar
evobunny
thanks for the response. wish there was one around I can check out.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
