R60 Does anyone have a Scangauge2 in their Countryman?
Old Feb 19, 2011 | 07:19 AM
Hobie44610's Avatar
Hobie44610
The CM does have an OBD2 port, right? I was just wondering if anyone has the Scangauge2 and monitors their turbo boost, engine oil temp, engine coolant temp, read codes, etc.
I've read on other threads that the CM S engine seems to take some time to warm up on a cold start and another threads where the CEL light comes on due to a high coolant temp code when the drier was driving through a snow storm.
Did a search and didn't come up with any Scangauge info on the CM.
TIA
Old Feb 19, 2011 | 08:21 AM
thebestbear's Avatar
thebestbear
I just saw it the other day.
Let me see if I can find the link.
Old Feb 19, 2011 | 12:42 PM
thebestbear
Here's a link for a scan gauge for R60: http://www.cravenspeed.com/products/...-II-Mount.html
If you have an android phone, I also thought this was cool too: http://www.cravenspeed.com/products/...plete-Kit.html
Old Feb 19, 2011 | 06:50 PM
03mini-S's Avatar
03mini-S
TIA
Yes, it has an OBD2 port.
Ours kept throwing a code which I confirmed was a high temp code on my OBD2 diagnostic tool. It turned out to be a defective thermostat. All good now since the dealer replaced it.
Old Feb 20, 2011 | 03:12 AM
Hobie44610's Avatar
Hobie44610
Thanks guys. I 've got one in my diesel where I need to keep an eye on the delta between the EOT and the ECT. Can also monitor the turbo boost, transmission fluid temp and a whole bunch of other info coming off the computer not to mention read codes and clear the CEL. It is well worth the $150 for the little unit. Blendmount makes a nice mount that secures the SG2 right above the rear view mirror.
I was just wondering if anyone already had an SG2 in their CM and if so what they are monitoring and if they've had any problems with the programming of the SG2 while interfacing it with the OB Computer of the CM.
It would probably be the first item I'd install. Data is good.
~Cheers
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
molala
Oct 2, 2015 01:53 PM
Sep 14, 2015 12:48 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
