Oil blow by 2013 Mini Countryman
Old May 8, 2022 | 05:19 PM
dnk1234's Avatar
dnk1234
After sitting at idle for more than 10 mins I get a big cloud of blue smoke when accelerating. I understand I likely have worn rings. The car has high mileage. Just wondering if there is a safe product to add to the oil to reduce the oil burn?
Old May 9, 2022 | 03:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
How many miles on the engine? In my experience, your situation sounds like a failing PCV system. You can either try to fix the PCV valve, or replace the cam cover. Will be much less expensive than an engine rebuild.
Old May 9, 2022 | 02:13 PM
PCV or valve stem seals in my guess. Valve cover is the easy thing change first.
spikeyadrian
Apr 11, 2020 08:49 AM
525iEnjoy
Aug 15, 2019 08:25 AM
ptguy0618
Sep 10, 2017 06:46 PM
smwzuu
May 17, 2015 07:59 AM
mattkosem
Oct 17, 2014 07:00 PM
