Proud Owner of a new Rescue
Hello All,
I have always been interested Mini's since i drove my buddies 1974 Right hand drive a few years back. Well, I am now the proud owner a of a new rescue. 2005 Cooper S with a 6 speed. She had been under a tree for rescue and was in desperate need of a bath. I have found there was a little work done to her. A WAIC intercooler, borla catback exhaust, wilwood calipers with slotted rotors. Looks to be updated springs but having just got her last night havent had a chance to get a good look. had 118k on the odometer. Seems to be taking care of fairly well and i am excited to be a Mini owner!
Side Note: How accurate is the Chrono pack Oil Pressure gauge? It seems to dip at idle when warm it is fine while moving, just at idle.
Thanks guys!
Also I will add pictures after i get her cleaned up a little.
Thanks guys!
ECSTuning (07-16-2019)
Hi and welcome to the NAM family!
Congrats on your new to you Mini!
An 05 R53 is a great car and a kick to drive!
The chrono package is rarer and a must for me! The oil will drop to 5 on idle, which is normal. How accurate is is, is questionable at best! It should go up half way while driving, or at fast idle.
Show us some pics and we can tell you more about it.
R53's are the best street legal go-karts!
Congrats!
She also needs the drivers side fender flare and the hood and hatch shocks. I am excited to get her up to snuff.
And here she is after her bath. Going to take some better pictures when I get better light and location and after a headlight restore.
Edit: Also fixed the passenger window. There was a loose bracket on the window that didn't allow the window to go up. Got it tore apart and tightened. No more water on the seat when I wash it!
RENNtech badge , was it tuned by them?
Ask them? They may have a record of it, either logged by the car's VIN or by name of the previous owner.
Regarding the oil pressure gauge, remember that the oil pump is mechanically driven by the engine. Oil pressure will vary by engine speed, and also by temperature. IMHO its main purpose is to tell you "hey boss, the oil done all fall out!" faster than the idiot light does. :-) That said when I had my R53 I liked seeing the gauge needle moving around. Reassuring, even if not super useful off the track.
Yep call them and/or looks at the side of the ecu. Its pretty rare but they do have some custom tunes.
Just remember this: Factory gauges are more of an indicator that something is working, but factory gauges are rarely accurate. The speedo is only close, the tach is only close, the temp gauge is only close, but so many people on this site seem to feel the oil pressure gauge is not good, because it is only close too! If it is moving around, it is "indicating" oil pressure, because it moves around, we should take comfort that oil is circulating and in my book, that is a good thing!
Note: If you are truly that paranoid, you should install an auxiliary oil pressure gauge. Be prepared to spend a lot to know the exact pressures, because those aftermarket oil gauges in general are only close too!
I just don't understand why so many are hung up on this!
Side note: The red idiot light for oil pressure on most cars come on way after the damage is already done. The gauge however inaccurate, shows the oil is moving! It does not matter that the pressure is read by the ecu.
I see six gauges moving. none all that accurate, but showing movement. I can live with that!
I still love this car. A lot more than I thought i would. After my new floor jack gets here(I had a really heavy duty one that would not fit under the car) I plan on getting that exhaust leak fix and do the brake pads. I know it needs the CPS o ring as well but that may be for the next weekend.
WOW. I just found the VIN decoder that someone posted and found out mine has the LSD too. Anyone want to help with some of these other options mean. Noticed it had the Auto A/C and the Cars A/C doesnt work at the moment, is it going to be harder to fix now?
210Dynamic Stability Control (dsc)Dynamische Stab. Control (dsc)
249Multi-function For Steering WheelMultifunktion Fuer Lenkrad
2REL-all. W. Web Spoke/runflatLm R. Web Spoke, 2-teilig/notlauf.
2TALimited Slip DifferentialSperrdiferential
345Chrome Line InteriorChrome Line Interieur
381Roof In Body ColourDach In Wagenfarbe
403Glas Roof, ElectricGlasdach, Elektrisch
405Exterior Mirror Caps Chrome PlatedVerchromte Aussenspiegelkappen
429Interior Surface, AnthraciteInterieur-oberflaeche Anthrazit
450Height Adjustment F Front Passenger SeatBeifahrersitz Hoehenverstellung
473Armrest, FrontArmauflage Vorn
520FoglightsNebelscheinwerfer
522Xenon LightXenon-licht
534Automatic Air ConditioningKlimaautomatik
547Cockpit Chrono PackageCockpit Chrono Paket
550On-board ComputerBordcomputer
5AARear Fog LampNebelschlussleuchte
645Radio Control UsRadio-steuerung Us
650Cd PlayerCd-laufwerk
674Hifi Loudspeaker System Harman KardonHifi-system Harman/kardon
692Cd Changer I-bus PreparationCd Wechsler I-bus Vorbereitung
895Additional VentilatorZusatzluefter
8SPCop ControlCop Steuerung
925Shipping Protection PackageVersandschutzpaket
9AAExternal Skin ProtectionAussenhautschutz
Options
1CASelection Cop Relevant VehiclesSelektion Cop Relevanter Fahrzeuge210Dynamic Stability Control (dsc)Dynamische Stab. Control (dsc)
So I finally got underneath this thing saturday in search of my exhaust leak. Could not find the exhaust leak for the life of me. I am guessing it is in the flex between the header and the cat. It needs the Hydraulic motor mount on top. I did find out it has a pulley kit on it. It is going on a lift in this weekend and i will try to get some numbers off of the pulley.
