North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   1st Gear (https://www.northamericanmotoring.com/forums/1st-gear-114/)
-   -   the windshield washer isn't working? (https://www.northamericanmotoring.com/forums/1st-gear/162653-the-windshield-washer-isnt-working.html)
poppy Jan 30, 2009 11:17 AM
The front washer is NOT working, yet the
rear washer is working fine. I realize one pump does both jobs. So is it a relay that has given up the ghost or...?
DaveTinNY Jan 30, 2009 11:27 AM
Open your bonnet and look on the left side of the engine compartment... make sure a black delivery hose isn't pinched. If it is, you'll block flow of the fluid to the jets. It's on the left as you look at the engine, BTW.
Do you hear the pump running when you call for fluid? That's probably it.
DaveTinNY Jan 30, 2009 11:42 AM
2 Attachment(s)
Here are a couple of photos I just took to illustrate better. My MINI is dirty!
Good luck.
poppy Feb 4, 2009 09:01 AM
Thanks for the reply Dave, first of all. It's not an issue of blocked fluid. The motor doesn't come on when actuated at the switch. It does when I engage the rear washer. No sound, no motion, nothing when I turn on the front. That's why I thought it was in a relay. I couldn't find anything other than a fuse for thae washer, and it was fine
