MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
Go Back   North American Motoring > Announcements > Vendor Group Buys
Not a member? Register now!
Welcome to North American Motoring !
» Main Menu
Upgrade Garage
» Latest Main Topics
need help identifying a...
ipod nano question
Whatever comes first?????
could BMW decide to kill off...
Grom audio adapter
Riss Racing 02 Simulator...
Brake pad problem
Unichip Destoyed My ECU
Oil Catch Can How-To!
Brake problem after Disc/Pad...
Advertisement
Vendor
 Aftermarket vendors
Thread Tools Display Modes
  #151
Old 02-22-2009, 08:12 AM
GBMINI's Avatar
GBMINI GBMINI is offline
Vendor
Gallery
Quote:
Originally Posted by erickvonzipper View Post
Once it's activated, you don't have to double flick to auto-raise the windows. Just flick once and release, and the window goes all the way up. That was the idea.
A double click is needed.
I think a few toggle switch panels have "noisy" switches that can fool the circuit into thinking one click is two!
Ian C. Gloucester, MA, USA (UK expat) driving GBMINI#4, aka GPMINI
  #152
Old 02-22-2009, 10:20 AM
ScottRiqui's Avatar
ScottRiqui ScottRiqui is offline
Gallery
Yep - MINI probably didn't put a whole lot of effort into "debouncing" the toggle switches, since the car's computer is likely programmed to ignore consecutive switch pulses that come within microseconds of each other (and that's if the computer is even able to detect the multiple fast pulses in the first place.)
But since your circuit intercepts the signals before they get to the computer, it gets to see all of the switch noise. I'm surprised you haven't had more problems than you have.
  #153
Old 02-23-2009, 08:17 AM
05 GoKart 05 GoKart is offline
Gallery
As advertised, the install is simple and the auto-up works great, Thanks, Ian!!!
Am unable to get the garage door opener circuit to work, though... have the raw leads version and although the light on your board goes on when the door unlock switch is held, the garage door doesn't move. And yes, there is an opener already on it
Tried reversing wires and still nothing. Any suggestions?
John Mods... Engine: Mini-Madness CAI & OCC; PU CF-scoop; MSD Coil; Mania RED IW; TSW EVD. Suspension: MM 22mm RSB; Koni FSDs with H-Sport springs; OMP STB & LSB; MM anti-mushrooming strut tower plates; PB. Brakes: Helix SS lines; R56 front brakes. Exterior: TSW JP; M7 SA. Interior: My own design Cabrio Rear Seat Delete; Ev's between-seats windscreen; Ira's Auto-up circuit; HK iPod Adapter; RVM--GONE!
  #154
Old 02-23-2009, 09:49 AM
GBMINI's Avatar
Vendor
Gallery
The circuit mimics pressing the transmit switch, so if the garage opens when you press the transmit switch, it should also when the MINI circuit "presses" the switch. So long as the two wires are soldered to the correct two points on the circuit, where the switch contacts go.
The battery, of course, must still be installed.
Some switches have four solder points, but two each side are linked together - then you have to solder to the correct two on opposite sides.
It's also possible that the remote range isn't good enough, when installed down behind the toggle switch panel.
Does the remote have a light that indicates when it's transmitting? That's a great help for diagnosis.
  #155
Old 02-23-2009, 01:39 PM
WolfGTI's Avatar
WolfGTI WolfGTI is offline
Gallery
Any possibility of still getting one of these?
Scout - 2002 Cooper S, Pure Silver / Black.
Stop - TSW rotors, Carbotech pads, Helix SS brake lines.
Turn - TSW springs, Koni yellows, IE fixed camber plates, IE rear swar bar, IE endlinks, IE adj. lower rear control arms, Cusco 1.5way 60% lockup LSD.
Go - Helix CAI, Helix 15% pulley, RMW bumpstick, Brisk plugs, RMW street exhaust manifold, Jetex 65mm cat back, Clutchmasters FX300 clutch & flywheel.
  #156
Old 02-23-2009, 02:14 PM
GBMINI's Avatar
Vendor
Gallery
Yes.
Remaining stock is now available to all. See link on first post.
  #157
Old 02-23-2009, 02:17 PM
PBGTIGLX PBGTIGLX is offline
Gallery
Oh, and welcome to NAM.
Thanks Erick. Actually I have a double identity on NAM. I just created this identity solely for the GB, as I had originally gotten in on the GB from posting on another board. Once the GB was officially transferred to NAM, I figured I had better use the identity I had on the other board when posting on this thread, if that makes any sense. I'm also PBGTIGLX...
  #158
Old 02-23-2009, 04:14 PM
erickvonzipper's Avatar
erickvonzipper erickvonzipper is offline
Gallery
Okay, well then welcome to both of you . . .
<a href=http://www.northamericanmotoring.com/forums/signaturepics/sigpic16898_13.gif target=_blank>http://www.northamericanmotoring.com...ic16898_13.gif</a>
www.usminiclub.com Obie: my '05 MINI Cooper - Jet Black, Premium and Sport packages, chrome side vents with white/clear repeaters, M7 STPs, K&N 57i intake, Megan Racing MINI Cooper cat-back exhaust, TSW engine damper, Alta 19mm anti-sway bar, Ian Cull anti-nanny circuit.
  #159
Old 02-23-2009, 06:28 PM
WolfGTI's Avatar
Gallery
Ordered
  #160
Old 03-18-2009, 03:06 PM
LilBeastie's Avatar
LilBeastie LilBeastie is offline
Gallery
Finally installed the auto-up circuit I've had for a month or so... EASY!! Great instructions, thanks for putting together such a wonderful package.
http://i700.photobucket.com/albums/ww8/MeBaffled/LB001Sig.jpg
  #161
Old 03-21-2009, 07:23 PM
Z06C5R's Avatar
Z06C5R Z06C5R is offline
Gallery
Got mine in today super easy, love it! Cured all my annoyances associated with the switch-panel in one shot!
* * * * * * * * * * 2005 MCS : 1971 Datsun 240Z * * * * * * * * * * *
  #162
Old 03-25-2009, 05:28 AM
CooperT's Avatar
CooperT CooperT is offline
Gallery
Just got mine installed! Glad this was offered. Been wanting one for a while! Simple install and works perfectly!
Tim C
  #163
Old 03-25-2009, 10:41 PM
Urn Urn is offline
Gallery
I finally installed mine this past weekend. It worked approximately 5 times then died. I tried reprogramming and no go. The LED no longer illuminates during the programming process. Yet, all of the std window features still work with the circuit installed?!
I sent a PM, but never got a reply. Can I get a replacement?
winetime69 (at) hotmail (dot) com
  #164
Old 03-26-2009, 06:57 AM
GBMINI's Avatar
Vendor
Gallery
You did not send a PM to the circuit creator. You did not send an email to the "contact me" link on the ordering page.
There has never been a failed circuit, but I suppose a first is always possible. It's much more likely an install error.
You can ship the circuit back for testing ... if you don't have the return address on the original packaging any more, then please email me for info
  #165
Old 05-31-2009, 09:50 AM
mpdwag's Avatar
mpdwag mpdwag is offline
Gallery
I finally installed mine today! Excellent instructions, and it works great! Thanks so much for a great product.
MPDWAG
03 Indi Blue/White MCS - Sport, Comfort, & Convenience Packages
  #166
Old 05-31-2009, 01:28 PM
GBMINI's Avatar
Vendor
Gallery
  #167
Old 06-03-2009, 08:16 AM
fguillont's Avatar
fguillont fguillont is offline
Gallery
Garage
i am interested in one where can i get one?
  #168
Old 06-03-2009, 12:58 PM
GBMINI's Avatar
Vendor
Gallery
They occasionally appear for sale on the NorthAmericanMotoring Marketplace
  #169
Old 07-08-2009, 02:15 PM
kkcshipp's Avatar
kkcshipp kkcshipp is offline
Gallery
Will there be another batch anytime soon?
  #170
Old 07-08-2009, 06:07 PM
GBMINI's Avatar
Vendor
Gallery
Not direct from me.
But with my support, an enthusiast aftermarket company is working hard to supply auto-up circuits within the next two months ... you'll hear more when they are ready to announce ...
  #171
Old 07-14-2009, 09:15 PM
-=gRay rAvEn=-'s Avatar
-=gRay rAvEn=- -=gRay rAvEn=- is offline
~ Mass Motoring Club ~
Gallery
Hi Ian,
I would really love one with the Garage door feature!
Put me down for it.
  #172
Old 07-15-2009, 06:28 AM
kkcshipp's Avatar
Gallery
What does the garage door feature get you? I don't have that feature on my 02 MCS so does that mean I could?
Quote:
Originally Posted by -=gRay rAvEn=- View Post
Hi Ian,
Put me down for it.
  #173
Old 07-15-2009, 10:07 AM
GBMINI's Avatar
Vendor
Gallery
(the GDO feature enabled you to connect to and trigger your garage remote using the MINI toggle switches)
I think it's extremely unlikely that GDO versions will be available in the future.
  #174
Old 08-03-2009, 06:28 PM
Dr Obnxs's Avatar
Dr Obnxs Dr Obnxs is offline
Vendor
Gallery
Auto-Up Circuits back in production
See this announcement for details.
Matt
FES Auto= Worlds Best Shiftlight-Ian Cull Auto-Up-High Current Relay Module-Auto Sportplus
'02 CR/W S, Bunch of fun mods... '08 NFR/S Clubbie, close to bone-stock...
Dr Obnxs' Musings: a blog about cars, energy, technology and more....
'65 Mustang Convertable, 5.0 EFI, 5-sp, 3.55 8.8", GR-350 Suspension, 271 WHP and a big effin' grin!
  #175
Old 08-03-2009, 07:36 PM
GBMINI's Avatar
Vendor
Gallery
For anyone wondering, Matt & FES have my full support!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
(SOLD)Auto Window/Sunroof Module for 1st Gen LannyMCS All other MINI parts and items for Sale (archive) 4 02-05-2008 05:09 PM
F.S. NIB auto window up kit 1st gen oldopelguy All other MINI parts and items for Sale (archive) 10 08-15-2007 09:15 PM
MINI Auto-Up circuits at MITM from GBMINI and Ian Cull! jsouz 1st Annual MINIs in the Mountains (2006) 30 01-28-2007 03:47 PM
auto-up/DSC auto-off and remote window circuits...can both be used? minizeeg Electrical 8 01-26-2007 07:37 AM
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.2.0
