FS:: Carista Bluetooth OBD2 Adapter NOW @ ECS | HPFP Issues Fixed
Old 11-18-2016, 08:50 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
New Carista App For Your MINI
Carista is a smartphone app that allows you to diagnose, customize, and service your MINI.
Diagnose:
Check your MINI's health and report any stored faults. Access manufacturer-specific diagnostics, clear fault codes and reset your CEL.
Customize:
Personalize the behavior of your MINI’s windows, lights and more, with a click of a button.
Service:
With Carista’s DIY tools, resetting your service indicator, or checking your launch control count becomes a 1-click action.
Engage:
Simply plug in the Carista dongle and download the app subscription from your play store.
Diagnose, Customize, Service
Fits:
R56 MINI Cooper / S / JCW (2007+)
R55 MINI Cooper Clubman / S / JCW (2008+)
R57 MINI Cooper Convertible / S / JCW (2009+)
R58 MINI Coupe' / S / JCW (2012+)
R59 MINI Roadster / S / JCW (2012+)
R60 MINI Countryman S/SX(All4)/JCW (2011+)
R61 MINI Paceman /S/SX(All4)/JCW (2013+)
Click HERE
MINI High Pressure Fuel Pump Replacement
We have included all the must need parts direct from the manufacturer for your Turbo MINI high-pressure fuel pump repairs.
This HPFP (High-Pressure Fuel Pump) is the main pressure behind the direct injection engine and is located on the side of the engine head. The HPFP is located on driver's side of the engine and assists the fuels system to deliver the higher fuel line pressure. Sometimes you will get a false start or a check engine light that contributes to loss of fuel line pressure.
Resolve those multiple issues and put the power back into your engine.
Uh-Oh, Now What!
Fits:
R55 MINI Clubman S / JCW (2008+)
R56 MINI Cooper S /JCW (2007+)
R57 MINI Cooper Convertible S / JCW (2009+)
R58 MINI Coupe' S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
Click HERE
R55-R59 MINI Cooper S/JCW Engine Replacement Parts
We have included all the must need parts direct from the manufacturer for your Turbo MINI engine repairs, from turbos to the vacuum system.
This vacuum system assists the power braking system in providing ample braking pressure and is located on the side of the engine head. The pressure converter sits behind it in the engine bay and assists the vacuum pump/turbo. It also contributes to the turbo system wastegate.
Finally resolve those multiple issues and put the power back into your engine and braking systems.
Uh-Oh, Now What!
Fits:
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE
If you've been putting off required maintenance options on your car, you shouldn't wait much longer. A little preventative maintenance can keep your MINI from ending up roadside and without power steering.
At ECS Tuning we carry ZF which is an OEM manufacturer for MINI with all the common services to help you avoid troublesome hang-ups and costly repairs. We also carry the CHF 11S fluid required for all the power steering system repairs.
Get it right or get it twice
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
R53 MINI Cooper S/JCW (2002-2006)
Click HERE
Old 11-18-2016, 11:40 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Carista for Gen 3 ? Timeline if you know?
Old 11-18-2016, 11:45 AM
Hello Minnie,
It will work as a basic OBD2 reader for the Gen1 and Gen3 MINIs, but they don't have the coding done yet. Gen1 might never have the coding but they have their eyes on Gen3 coding. No time frame yet. But once we know we will post up. Should not be that long. You could still get it and then when it comes up update the app/subscription.
Old 11-19-2016, 06:51 PM
TG.'s Avatar
TG.
TG. is offline
So how do I know if the customization features will work on an R59?
Ultimately I'm still looking for the one touch window up, which is not clear this can do?
But I'm curious about other customization features as well such as "Lower passenger-side mirror when in reverse gear (req. memory seats)"
I'm also interested in BMW mini specific code reading and reset. How well does this system handles those?
Old 11-30-2016, 09:00 AM
I just updated my R58 JCW and the key fob closes windows, which is really cool. From the factory we already have the open windows and top with the key fob. And also the open both doors locks on 1 press of the key fob also was added to my car.
I am going to try "Lower passenger-side mirror when in reverse gear (req. memory seats)".
Will update as I get to mess with this more with specific models. The lists are on their site when you select your model. They update with features every so often.
Old 12-07-2016, 06:34 AM
One touch Auto up works!!!
I could not get "Lower passenger-side mirror when in reverse gear (req. memory seats)". " I believe its only for certain euro cars.
It will read and clear codes.
Old 12-08-2016, 09:59 AM
TG.'s Avatar
TG.
TG. is offline
I'm interested. I'll look into it. Shame their suscription plan isn't the most convenient/friendly... it's not a show stopper, but makes the use a little awkward. One sort of have to define the occasional one time use from more frequent use. I'm not a big fan of their suscription plan. But if the system works it still is interesting
Old 12-08-2016, 02:45 PM
Welcome. Now since they are onboard with ECS and MINI there will be more options down the road.
Its simple, quick, and easy. Not line code and finding codes to program yourself. Its easy to use on the iPhone.
Old 12-08-2016, 02:57 PM
JustinGTP's Avatar
JustinGTP
JustinGTP is offline
You need mirror package for that to happen.
On BMW cars, you need memory seats as that gives you the connection of mirrors to canbus, which is why it says req memory seats. On the MINI side because we dont have memory till 3rd gen, it really should say needs 313 mirror pack.
Im an avid coder through ncsexpert (not carly or carista)
Old 12-11-2016, 09:52 AM
TG.'s Avatar
TG.
TG. is offline
Cost . . . and trial?
Okay it all comes down to cost...
Carista gives you two cost models:
1. - One week for $9.99. I cannot help but think it is definitely too short and excessive. Give me $10 for a month. Okay I'll bite and can do that on occasion when I need it. But for 1 week??? that's a bit frustrating to make this useful.
2. - One year subscription for $39,99 WITH a 1 month free trial. I think that is more reasonably priced but:
How easy it is to cancel the free trial if I just want to see what the app can do but don't want to feel pressed by time with the $9.99/week subscription where I only get one little week to play with it? Anyone knows what's up with the free month trial? Will they make it hard to cancel? Can I get the free trial and switch to that silly 1 week subscription once I know better how useful it will be for me?
Old 12-12-2016, 06:43 PM
TG.'s Avatar
TG.
TG. is offline
Gave it a trial, "one touch window down" is not a listed customizable option on the R59...
No "one-touch window" options are listed for that matter. It sounds like that functionality is really buried deep in BMW coding for some reason... only NCS like coding is able to handle. Sigh...
I'll start another thread for the rest...
Although once more I'm disappointed on that specific item, it may still be a nice little tool/app to have for other things...
Old 12-13-2016, 05:03 AM
Its was on the R58. I will contact them and see why its not showing. It showed for Mine.
Old 12-14-2016, 12:49 PM
Did you restart the app and make sure its updated to the latest updage. Are you seeing it yet?
Old 12-14-2016, 06:16 PM
TG.'s Avatar
TG.
TG. is offline
I'm sure I have restarted the app at some point. I'll try again once more.
Also, I contacted them. He's very helpful. It would seem it is only in a beta version for now and he's not sure if it will work yet. I might help him out beta test We'll see. I'll keep you posted...
Old 12-16-2016, 01:30 PM
TG.'s Avatar
TG.
TG. is offline
Hoorah, the day has finally come! I was able to be part of Carista's beta tester, AND they have the one touch up window feature available in their beta version, WHICH I just tried and it works! I can't tell you how much nicer this is going to be. I'm so use to it on my other car that every time I'm annoyed by it in the Roadster. But not anymore!
So for those who are thinking about Carista for any MINI but obviously for the R59 also, give it a shot. It sounds like added functionality will be coming
Old 12-02-2017, 08:14 AM
Racingguy04's Avatar
Racingguy04
Racingguy04 is offline
Does this work with R53? can I change windows and light options with it, or just use it to read/clear check engine codes?
Old 12-04-2017, 08:25 AM
It will only read codes and check engine information. Clear codes. For the Gen 1 MINI.
Ment for gen 2 MINIs.
For the coding:
Old 07-21-2019, 06:33 PM
IVY_BR4's Avatar
IVY_BR4
IVY_BR4 is offline
Does the Carista read mini specific codes like anything related to half check engine light?
Old 07-22-2019, 06:19 AM
Hello, its more of a simple reader and reads some MINI specific codes(like a bonus option for coding options). If you want a code reader thats more indepth you will need this: https://www.northamericanmotoring.co...d-q-and-a.html
The Carista is more for simple precoded changes on options and equipment on your MINI.
