SneedSpeed Mini R53 Brake Cooler Kit
You’ve watched, waited and stayed cool. You’ve prepared for this moment; it’s time to make your move. You flinch to the inside; he dives to block, but you aren’t there. You faked him, out braked him, and passed him to take the line, the position and the glory. You knew your brakes would hold when things got hot with the Sneed4Speed Brake Cooler Kit.
Sneed4Speed Brake Cooler Kits– another product that comes directly from the Sneed's Speed Shop race program. After destroying the MINI S brakes on the track, we knew something had to be done to cool them down. That's when the Sneed Speed brake cooler kit was born, after we started using it we not only extended the brake life but dropped down one pad compound in the heat range.
The Sneed4Speed Brake cooler kits were designed to help track and race MINIs keep their brakes from overheating. Overheated brakes can cause all kinds of problems from poor pad and rotor life to total brake failure. Our kits are designed to keep your brakes strong and consistent lap after lap by lowering brake fluid, brake rotor and pad temps helping the life of not only your brake system but your cars wheel bearings and hubs too. The kits channel forced air from the front bumper through 3” motorsports grade high temp, highly flexible ducting directly to the front brakes.
Spec Sheet:
Lightweight steel backing plates with hose mounts
Lightweight Bumper brackets
3” flexible high temp brake duct hose
Clamps and bolts
Directions included for installation
Spec Sheet:
Clamps and bolts
