SneedSPeed Mini R53 Stud conversion kit
Your wheel stud and lug nut are the only thing holding your wheel on at 100+ MPH!!
Made in USA for race applications.
These 12mm x 1.5 thread wheels studs are custom made for MINI race applications. They are 92mm total length with 16mm of bullet nose, 51mm of lug nut thread, 10mm of shank and 15mm to thread into the wheel hub. Heat treated with rolled threads and rated at 190,000psi. These wheel studs work with hub centric spacers up to 20mm. Lug nuts use standard 17mm socket for installation. Designed for use in both stock and aftermarket wheels with 60 degree taper. Coated yellow, to prevent rusting and for easy locating on the ground or in your tool box.
Includes 16 lug nuts and studs.
Spec Sheet:
Wheel stud total length- 92mm
Lug nut threaded length- 51mm
Bullet nose length- 16mm
Shank length- 10mm
Thread wheel hub end length- 15mm
Spec Sheet:
Shank length- 10mm
