:: ECS Tuning :: Clutch Conversion | Shift Lights | Trans Kits & MORE
Fumoto Oil Drain Valve For Your MINI R50/R53
The Fumoto oil drain valve replaces your OE drain plug for fast, easy oil changes.
Its spring-loaded valve has a quick release tab that makes changing oil a snap. Just push and turn to drain.
All-metal construction assures years of trouble-free service. Includes a threaded brass extension for oil pans with recessed drain plugs.
A good idea. Long overdue.
Quick Change Artist
Fits :
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE For FUMOTO valve
Clutch Kits & More For Your R53 MINI Cooper
Here are some frictional characters you can believe in.
ECS Tuning has clutch kits that let you restore the smooth clutch operation and performance you expect from your manual transmission.
Knowing that one size can't possibly fit all, we've gone out of our way to give you the choices you want. From brown bag stock to hybrid-mix kits combining original equipment and specialty performance upgrades, you're sure to find the clutch kit that suits your needs, and exceeds your expectations.
If your clutch has swapped grip for slip, order soon.
Fits:
Click HERE For clutch options
ECS Clutch Kits For Your MINI R50/R52
While changing your own oil gives you the confidence of knowing your vehicle and how to address its basic needs, using inappropriate parts and fluids will soon prove to be counterproductive and damaging.
The wisest and most thorough approach is to invest in a complete Oil Service Kit.
ECS-assembled and genuine MINI Oil Service Kits have been scrutinized by our in-house engineers so you can back up that confidence of having done the job on your own.
Do It Right.
Fits:
R50 MINI Cooper (7/2004-2006)
R52 MINI Cooper Convertible (7/2004-2006)
Braking Essentials For Your MINI R60/R61
ECS is your one stop shop for all your braking needs.
ECS Exact-Fit stainless reinforced brake lines provide more confident and consistent stopping by maintaining consistent brake pressure, long lasting corrosion resistance, and increased protection from failure.
When addressing a vehicle's braking system, it can be easy to overlook brake fluids, ECS has assembled three Brake Fluid Flush Kits to suite your needs.
One Click
Fits:
R60 MINI Countryman S/SX ( ALL4 ) (2011+)
R61 MINI Paceman S/SX ( ALL4 ) (2013+)
Click HERE For brake Options
Transmission Essentials For Your MINI R56
Your MINI transmission is a collection of parts that must each be functionally sound for the gearbox to do its job.
It follows then, logically, that when attending to a particular transmission issue, the strength of the weakest part determines the end quality of the system.
For this reason, ECS offers several complete Auto Trans Service Kits for your MINI, as well Clutch Masters Clutch Kits.
Do It Right.
Fits:
R56 MINI Cooper S / JCW (2007-2013)
Click HERE For kits
NM Engineering Short Shift Adapter | MINI F55/F56
NM Engineering’s short shift adapter is made utilizing CNC machined T303 stainless steel billet. The adapter features easy install that makes replacement of the entire shift lever not necessary. Installation can be done by accessing the shifter assembly box from below the car. This kit will reduce shift throw by approximately 20%.
Short and Sweet
Fits:
F56 MINI Cooper / S (2014+)
F55 MINI Cooper / S (2014+)
Click HERE For short shift kits
MINI R56/R55/R57 Kohlefaser Luft-Technik Intake System
"Good things come to those who wait." This proverb is arguably the best definition for our ECS Tuning Kohlefaser Luft-Technik (Carbon Fiber Air Technology) Intake System.
In house developed, engineered and tested, this air induction system is THE BEST production induction system on the market today.
With months of rigorous testing and design innovations we are proud to release this complete kit to power your MINI.
With more power, higher quality materials and stunning aesthetics, this induction system will exceed expectations.
The Apex of Induction Engineering
Fits:
R56 MINI Cooper S/JCW (2007-2013)
R55 MINI Clubman S/JCW (2008-2014)
R57 MINI Cooper Convertible S/JCW (2009+)
Click HERE For intake options
[/CENTER]
08-07-2015 09:51 AM
08-05-2015 02:11 PM
08-05-2015 02:10 PM
