:: ECS Tuning :: R52/ R53 S Mishimoto Radiator | ECS Carbon Fiber INTAKE | Xenon KITs
Old 01-30-2015, 05:52 AM
ECSTuning is online now
Received 1,964 Likes on 1,764 Posts
MINI R57 Trunk Lid Grip
Are you having trouble getting into your trunk?
ECS Tuning has the solution with this Trunk Lid Grip which includes the trunk lid with internals (available in Primed and Chrome), and the lock mechanism. This kit will allow you to fix the rear hatch button grip with an easy, all-in-one kit.
Available in both Primed and Chrome, if necessary the primed handle can be replaced by your painted handle already on your vehicle.
Fix that trunk.
Fits:
R57 MINI Cooper Convertible / S (2009+)
Click HERE for grip replacement
R52/R53 Cooper S/JCW Mishimoto Radiator
Whenever pushing your car past the factory-designated limits of operation, be it through hard driving or performance modifications, adequate engine cooling should always be a high concern.
In fact, improving performance by increasing engine work is only possible when engine temperatures are kept within a reasonable range.
The Mishimoto Performance Radiator is capable of a 30% increase in cooling capacity due to a fully-brazed, two-row aluminum core that's 25% thicker than stock. The direct-fit radiator also uses CNC-machined quick-disconnect fittings for perfect fitment.
Radiate Excellence
Fits: Gen 1
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for Mishimoto
R50 R52 R53 ECS GEOMET® Brake Rotors
GEOMET® is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
Slotted or drilled and slotted, you can expect your new GEOMET rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Stopping Never Looked So Good
Fits: MINI
R50 Cooper (7/2006+)*
R53 Cooper / S (7/2006+)*
R52 Cooper Convertible / S (7/2006-2008)*
*Not For vehicles with JCW Brakes
Click HERE For the ECS Geomets
B]MINI R55/R56/R57 Genuine Xenon Headlight Kit[/B]
The headlight design of the MINI Cooper defines the car's character more so than any other feature.
MINI is now offering stunning Bi-Xenon headlights in Titanium-Gray housings for the 09/2009+ Cooper.
The genuine MINI kit includes left and right side headlights, and retains the factory clear turn signals.
NOTE: Additional coding will need to be done by a MINI dealership for strobe light elimination on startup.
A Clear Improvement
Fits:
R56 MINI Cooper /S/JCW (9/2009+)
R55 MINI Clubman /S/JCW (9/2009+)
R57 MINI Cooper Convertible /S/JCW (9/2009+)
*Vehicle will need programmed by dealership to activate headlights after install.
Click HERE For the 25w Xenon kit
R50-R53 MINI Viaco Lower Control Arm Bushings
Is your MINI Cooper making noises over bumps, or does your steering feel loose and less responsive than it once was? The control arm bushings are a big cause of front suspension problems, and the only remedy is to replace them.
This kit was built by the experts at ECS Tuning, and it includes both lower control arm/wishbone bushings. Both bushings are already pressed into their brackets, so you won't have to worry about renting or buying the equipment needed to press the bushings in. Fix your front suspension issues today with this kit from ECS Tuning.
The Best Remedy
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible / S/ JCW (2006-2008)
Click HERE for kits
R60/R61 Forge Diverter Valve Upgrade
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces.
Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids.
Install PDF included on flash drive*
Forge Ahead.
Fits:
R60 MINI Countryman S / SX / JCW (2011+)
R61 MINI Paceman S / SX / JCW (2013+)
Click HERE for FORGE
__________________________________________________ ___________-__
MINI Cooper R50-R53 R113 JCW Wheel & Tire Sets Of Four
ECS now offers a superbly matched wheel and tire set from legendary MINI tuner JCW. The 18-inch JCW LM Rad Cross Wheels are finished in Gloss Turned Black or Gloss Black and are wrapped with Pirelli P Zero or Bridgestone Potenza RF asymmetrical Run Flat High performance tires.
The combination not only perfectly complements any MINI's styling, but offers fitment, quality, and performance only possible through JCW. The balanced wheels with MINI JCW center caps and TPMS sensor arrive ready to mount - just top off with air and drive.
The Works
Fits: MINI
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for Wheel Sets on SALE
MINI Cooper S/JCW ECS Kohlefaser Luft-Technik Intake
"Good things come to those who wait." This proverb is arguably the best definition for our ECS Tuning Kohlefaser Luft-Technik (Carbon Fiber Air Technology) Intake System.
In house developed, engineered and tested, this air induction system is THE BEST production induction system on the market today.
With months of rigorous testing and design innovations we are proud to release this complete kit to power your MINI Cooper S/JCW '07+.
With more power, higher quality materials and stunning aesthetics, this induction system will exceed expectations.
The Apex of Induction Engineering
Fits MINI:
R56 MINI Cooper S/JCW (2007+)
R55 MINI Clubman S/JCW (2008+)
R57 MINI Cooper Convertible S/JCW (2009+)
R58 MINI Coupe' S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
R60 MINI Countryman S/SX/JCW (2011+)
R61 MINI Paceman S/SX/JCW (2013+)
Click HERE for ECS Carbon Fiber CAI
R50-R53 R105 JCW Wheel & Tire Sets Of Four
ECS now offers a superbly matched wheel and tire set from legendary MINI tuner JCW. The 18-inch JCW Double Spoke Wheels are finished in Bright Turned Black or Matte Black and are wrapped with Pirelli P Zero RF asymmetrical Run Flat High performance tires.
The Works
Fits:
Click HERE for Full Wheel Sets on SALE
R56+ R105 / R113 JCW Wheel & Tire Sets Of Four
The Works
Fits:
R56 MINI Cooper /S/JCW (2007+)* ,
R55 MINI Cooper Clubman /S/JCW (2008+)* ,
R57 MINI Cooper /S/JCW (2009+)* ,
R58 MINI Cooper /S/JCW (2012+)* ,
R59 MINI Cooper /S/JCW (2012+)*,
*JCW 4 Piston Brake kits will need 5mm spacer for front wheel fitment.
Click HERE for JCW Wheel sets on SALE
01-04-2019 12:51 PM
marendt428
02-25-2016 07:13 AM
08-12-2015 01:24 PM
marendt428
08-09-2015 06:54 PM
OutMotoring
08-06-2015 09:32 AM
Quick Reply: :: ECS Tuning :: R52/ R53 S Mishimoto Radiator | ECS Carbon Fiber INTAKE | Xenon KITs
