:: ECS Tuning :: Gen 1 ECS STP / SCHROTH Gen 2 / F56+ Oil filter Kits / HUF TPMS Sets
R50/R52/R53 MINI Cooper ECS Strut Tower Plates
The strut tower for the MINI Cooper was designed to adequately support the stresses and forces encountered during typical daily driving.
Aging models or vehicles that are routinely pushed past the limitations of the chassis oftentimes experience strut tower deformation, compromising the crisp and responsive handling that defines every MINI.
Machined from 15mm thick 6061-T6 aluminum, ECS Strut Tower Plate Kits eliminate the prospect of tower mushrooming while improving chassis rigidity.
ECS Smart and Simple
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for ECS Strut Tower Plate kits
Click on products to see install PDF under product info !
R55 R56 R57 MINI Schroth Quick Fit Harness
A frequent dilemma when fitting an upgraded seat belt to track-prepared street cars is how to balance the needs of daily driving with the demands of performance driving.
A dedicated track-day setup is typically impractical, while running without a substantial harness forces the driver to use the steering wheel to hold themselves in place.
Schroth Racing Quick Fit Harnesses are fully reversible and anchor to the factory seat belt pre-tensioner, allowing the airbags to deploy as the MINI engineers intended.
Both left (driver) and right (passenger) harnesses are available.
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE for the Schroth Sets
R55 Clubman H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI R55 Clubman an average 1.4" in front and 1.4" in the rear for a lower center of gravity, improved handling, and a more aggressive appearance.
Sport springs are an excellent choice for street and occasional track use, featuring a spring rate that is firmer than the OE Sport spring but still comfortable enough for daily use.
A Tasteful Upgrade
Fits:
R55 MINI Clubman Base (2008+)
Click HERE For the H&R kits.
R53 Mini Cooper S/JCW ECS Silicone Hose Kit
Doing a cooling system refresh, or just replacing worn out and soft old hoses? Why settle for stock when you can get the added life and heat tolerance of silicone hoses? The ECS Silicone Radiator Hose Kit retains OEM fitment while resisting heat that softens the factory hoses.
All hoses come in advanced 3-ply black silicone.
Don't Get Hosed
Fits MINI:
R53 Cooper S / JCW (2002-2006)*
*Manual Transmissions Only
Click HERE for Silicone hose kits .
MINI Gen1 Power Steering Repair Kit
The MINI power steering line repair kit was made to repair both the return and suction line that are located between the power steering pump and reservoir.
These lines are known to leak, requiring replacement. Genuine MINI parts guarantee fitment and longevity, so you take care of this job the right way the first time.
The kit is complete - The power steering return line, suction line, suction line clamps (upper and lower), return line upper clamp, two return line washers, sealing ring, and hollow bolt are all included.
Steer Clear
Fits MINI:
R50 Cooper (2002-2006)
R52 Cooper / S / JCW ( 2005-2008 )
R53 Convertible / S / JCW ( 2002-2006 )
Click HERE for PS repair kit .
R60 Mini Countryman Ziza LED Interior Lighting Kits
Some products need to be experienced to be appreciated.
We can talk about our LED interior lighting kits, but words will fail. We can describe the light as bright and white, crisp and clean. We can even tell you that our complete interior LED kit will banish ugly yellow illumination and showcase the rich features of your dash and interior trim like never before, but it won't do them justice.
Oh well. Guess you'll just have to take advantage of our free shipping on full kits, and see for yourself what a dramatic change LEDs can make to your car, both inside and out.
Ziza; Light Years Ahead
Fits:
R60 MINI Countryman Base (2011+)
R60 MINI Countryman S (2011+)
R60 MINI Countryman SX All4 (2011+)
R60 MINI Countryman JCW (2012+)
Click HERE for the Ziza kits
MINI F56 Oil Filter Sets
There's no way around the fact that over the life of your F56 MINI, you'll be changing the oil and oil filter many times. If you're especially fond of your Cooper, you'll change your filter even more frequently - metallic particles floating around in your oil must be filtered out to preserve the mechanical efficiency of your engine.
ECS has assembled a highly economical solution for the prudent MINI owner with Oil Filter Sets, available as 5 or 10 complete filter changes that include an oil filter, oil housing plastic drain plug, and an oil pan drain plug crush washer.
Bulk Up
Fits Mini:
F56 MINI Cooper / S (2014+)
Click HERE for oil filter sets
R55-R59 MINI Huf Tire Pressure Sensors
Tire pressure monitoring is a convenient feature - when it's working properly.
Too often, when the tire pressure light illuminates in your MINI, the cause has nothing to do with the pressure inside your tire.
A worn tire pressure sensor is usually the culprit, sending false readings to the ECU, causing unnecessary concern to the driver.
ECS offers replacements sold individually or as a set of four. After installation, simply navigate to the TPM screen to clear the light from your dash.
Also great as a set of four when upgrading or changing to new wheels.
One Less Dash Light
Fits:
R56 MINI Cooper /S/JCW (9/2009+)
R55 MINI Cooper Clubman /S/JCW (9/2009+)
R57 MINI Cooper Convertible /S/JCW (9/2009+)
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for the Huf TPMS sensor kits
07-16-2020 12:54 PM
08-12-2015 01:24 PM
08-10-2015 02:03 PM
08-10-2015 01:59 PM
08-05-2015 02:11 PM
