:: ECS Tuning :: Gen1 S Coolant tank|| F56 H&R Springs NEW* || R60 & R61 H&R New*
Old 08-26-2014, 01:05 PM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
MINI R52/R53 Cooper S/JCW Coolant Expansion Tank
Continual heat cycling and system debris will crack and eventually stain the expansion tank, also referred to as the coolant recovery bottle.
Aging coolant tanks can cause several problems, including coolant loss, a leaking pressure cap that lowers system pressure, and a failed low-coolant level sensor.
Now you can address all of these issues at once--or head them off before they become bigger problems--with a new coolant expansion tank for the R52/R53 MINI Cooper.
The direct-fit tanks come ready to install with a new pressure cap.
Essential Prevention
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for Expansion Tanks
MINI Cooper F56 H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI an average 1.1" in front and 1.1" in the rear for a lower center of gravity, improved handling, and a more aggressive appearance.
Sport springs are an excellent choice for street and occasional track use, featuring a spring rate that is firmer than the OE Sport spring but still comfortable enough for daily use.
A Tasteful Upgrade
Fits :
F56 MINI Cooper Base / S (2014+)
Click HERE for the H&R F56 springs
MINI Countryman R60 H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI an average 1.4" front and 1.4" rear for a lower center of gravity, improved handling, and a more aggressive appearance.
A Tasteful Upgrade
Fits MINI:
R60 MINI Countryman Base (2011+)
R60 MINI Countryman S (2011+)
FWD only.
Click HERE for R60 H&R Sport Springs .
R58/R59 MINI Door Brake Kit
Clicking or sticking doors are typically the result of a failed or worn door brake.
ECS offers genuine MINI Front Door Brake replacements, giving your R58 / R59 MINI Cooper a factory feel when opening and shutting your front doors.
The door brake attaches to the side of the door jam and mounts inside the front of the door.
Driver and passenger side doors use the same unit, with one door brake required per side.
The Simple Solution
Fits:
R58 MINI Coupe /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for ECS MINI Door Brake Kits or for more information.
MINI Paceman R61 H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI an average 1.3" in front and 1.25" in the rear for a lower center of gravity, improved handling, and a more aggressive appearance.
A Tasteful Upgrade
Fits:
R61 MINI Paceman (2013+)
R61 MINI Paceman S (2013+)
R61 MINI Paceman SX (ALL4) (2013+)
Click HERE for MINI Paceman H&R Sport Springs.
MINI R50 R52 R53 ST X Performance Coilover System
The lowered ride height achieved by upgrading your factory suspension is a consequence of the modification, not its purpose.
With this knowledge, you can appreciate the value of more finely wrought suspension designs, like those from ST.
The ST X Performance Coilovers utilize tempered high-strength springs, hardened chrome piston rods, and galvanized zinc-plated strut housings - a consequence of which is a powerful, aggressive stance. But the enduring value of this arrangement lay in its durability, reliability, and reverence for precise engineering.
The Ultimate in Performance
Fits: Gen 1
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible (2005-2008)
Click HERE for the R50 R52 R53 MINI ST X Coilover kit
08-12-2015 01:24 PM
08-10-2015 02:03 PM
08-10-2015 01:59 PM
08-05-2015 02:11 PM
08-05-2015 02:10 PM
Quick Reply: :: ECS Tuning :: Gen1 S Coolant tank|| F56 H&R Springs NEW* || R60 & R61 H&R New*
